Question about Garmin GPS 12 GPS Receiver
Internal battery dead,how to replace
How do I change the internal battery in my garmin 12 as I loose all data when I turn it off or change external batteries. Thanks
    Problem Solver:
  • 10 Answers
The GPS 12 has an internal battery soldered to the board inside the unit.
I have replaced about a dozen of these over the years,
The problem is caused when the unit is stored for a long time without batteries.
The internal battery is not a rechargable.
You have to use a screwdriver in the crack that joins the 2 parts of the case and break the seal to split the case open.
This will of corse render the waterproofness of the unit void.
You then have to unsolder the internal battery from the board and find a replacement.
It is a tagged lithum battery, I can't remember the model at the moment.
Inside you will also notice the surface mount Intel 386 Chip. which is the main processer.
This has nothing to do with the battery but I found it interesting that a chip in a computer from the mid 80s worth over $3000 then, still has a use.
When you have soldered the new battery into place you need to either glue or tape the unit back together. Be careful not to damage the other parts around the battery.
Always keep charged batteries in the unit when not in use.
Hope this helps.
Alan
Posted on May 12, 2009
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
Garmin gps 12 loss of data
I had the same thing happen. The problem is that the internal lithium battery is shot. Solution: phone Garmin at 1-800-800-1020 x 2,2,1. You send the receiver in along with a $42.41 check. They will probably replace the unit. They will explain exact procedures when you call.
Hope this helps.
Joan
Jan 04, 2010 | Garmin GPS 12 GPS Receiver
C340 is showing low battery. how do i change the battery?
It has a 12 volt power cable for the internal battery. Do you have the cable - refer to the owners manual (free download via the Garmin site) for more info. The internal battery is not normally replaced.
Nov 03, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin gpsmap 295 will not run from internal battery power
I had the same problem. Reluctantly, I removed the batteries and the 8 phillips screws from the the case back perimeter. Be careful on opening. The unit is designed to open from the top and hinge at he bottom to keep the ribbon cables from being stressed. The unit should open nicely and lie flat on the table with the two bottom halves butted against each other. Get a magnifier and ensure the printed circuit board attached to the bottom half has all 3 screws. (I found one missing that has 2 functions - securing the board and delivering battery power. Mine had wedged against a piece of clear plastic...it was hard to find!!!) I carefully removed the wedged screw and returned to the circuit board left most attach point. Close up the unit and we were back in GPS heaven. Battery power restored!!!! and my $250.00 still in my pocket. Yipppeee.
Jun 30, 2009 | Garmin GPSMAP 295 GPS Receiver
Wrks as expected, external power us, but intermittently turns off
The connectors are obvious, careful when youopen it up as the wires aren't very long! Look at the internal battery - it may be corroded looking - which is a sure sign it's gone west. Lots of info online on replacing it, you can try carefully snipping one of the battery leads and see if the sympton changes. Good luck
Mar 13, 2009 | Garmin GPS III
Internal Battery Low
Same problem. Remove the 8 screws, unsolder the battery from the circuit board, pry off leads, place electrical tape around edge of new battery, solder on the leads, solder leades on circuit board. Remember which side was up before soldier, close unit, you should be good to go.
Aug 14, 2008 | Garmin GPSMAP 180 GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin IQue M5
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
May 31, 2008 | Garmin iQue M5 GPS Receiver
When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Sep 18, 2007 | Garmin iQue 3600 GPS Receiver
Garmin GPS 12 GPS Receiver Logo
1,444 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
