Question about DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker
Cafe verona delonghi
Brews esspresso, no steam
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Posted on Oct 09, 2007
Make the coffe portion work again
This category is for printers and copiers, please submit your problem in the appropiate catergory.
Sep 21, 2014 | DeLonghi Cafe Nero BCO-264B Coffee Maker...
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Alicia perle H20
H2O is the chemical formula for water - maybe it needs filling with water ?
Sep 22, 2017 | Cameras
Help received the Delonghi Cafe Nabucco machine from a friend .no instructions ,how do I make expresso ,capp steam milk etc?
Go to the above link and download the manual for the BCO 120T
It should provide the basics to get you going
Making a good espresso with steamed milk takes practice
If you don't have the frothing pitchers.. buy a couple in different sizes
Used cold low fat or non fat milk..
It takes practice to get good at it.. a hand on the side of the pitcher to make sure you don't scald the milk.. etc.. you don't want the milk to bubble/boil..
If you have a control valve for the steam pipe.. immerse the pipe about an 1/2 inch or so into the cold milk and slowly open the valve.. until you have it open full. Jostle the pitcher to move the milk around pretty much during most of the process once it begins to warm and foam.. raise the pitcher to heat the milk in the bottom .. then lower it as the foam begins to form...never letting the steam pipe out into the froth. Once done..wipe the pipe clean with a wet cloth.
Grind of the coffee is imporant as well as the roast and when you fill the portafilter don't over tamp.. If you pack it to tightly.. won't brew... too loosely.. brews too fast.. You want to see the coffee shots come out and form what's known as crema... which is a thin layer of tan or light brown foam on top of the shot. If aren't getting this..the coffee is either ground wrong or packed too tight.
It's an art..and nothing beats practice.. there are scores of books and internet threads on how to froth milk and make different coffee drinks..
I love a good Cafe Borgia now and again.. we live in the Portland, Oregon area.. everyone here is addicted to the bean..
Best of Luck
Apr 29, 2011 | DeLonghi Caffe Nabucco BCO70...
I just need to know how to make a cappuccino useing my DeLonghi Cafe Sorrento. Thanking you
Cappuccino is a mixture of espresso, a little steamed milk and a little milk foam. The milk/foam ratio is up to you what you enjoy most. Some like a thick layer of foam while others just want foam as a garnish on top. Mix as you please.
Feb 22, 2010 | DeLonghi Cafe Sorrento Espresso Machine
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
Where do i put the milk?
Please follow this LINK
Than go to instruction manuals.
Food preparation. Coffee and espresso makers. And click on BCO70
that will give you your instruction manual
Jun 05, 2008 | DeLonghi Caffe Nabucco BCO70...
Delonghi BC0255 steam output
The contact number for Delonghi should be 1 (800) 322-3848.
Apr 08, 2008 | Espressione Cafe Roma Deluxe 1329
DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker Logo
840 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
