SOURCE: PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
SOURCE: loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true;
'' + google_ads[i].line1 + '
'' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
google_ads[i].visible_url + '
var adsByGoogleRight = "-40px";
if(dartRecieved){
document.getElementById("ga_300x250").style.clear="both";
document.getElementById("ga_300x250").style.left = "0px";
document.getElementById("inner_adv_caption").style.display = "block";
document.getElementById("ga_300x250").style.width = "370px";
adsByGoogleRight = "5px";
else if(isHealthinationExist){
var healthinationBox = $('healthonationBox');
if(healthinationBox){
var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight;
var ga_top =getObjXY(document.getElementById("ga_300x250"))[1];
if(ga_top-helthinationBot >0){
document.getElementById("ga_300x250").style.width = "530px";
else{
document.getElementById("ga_300x250").style.width = "410px";
$('boxAdWrapper').style.display = "none";
else{
//add "ads by google"
var logo_img = '';
s += '' + logo_img + '';
document.getElementById("ga_300x250").innerHTML = s;
var currl = $('related_links');
var currq = $('related_questions');
if(currl!=null && currq!=null){
var currltop = getObjXY(currl)[1];
if(currltop > rltop )
currq.style.clear="left";
return;
SOURCE: loading paper
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
SOURCE: how to feed paper into a canon palm size printing
There should be a small slot in the rear, gently feed the end into it while pressing the paper feed/advance button.
SOURCE: We can't figure out how to feed the new paper into
The calculator wouldn't take the paper but when he cut the corners off the paper to make a blunt "V", it grabbed the paper right away and pulled it through.
