Question about Arris DCT6200 DTV Receiver
Connections how do you hook up this reciever box to a jvc thc-50 home entertainment system and a hitachi 65f-59a hdtv so you can listen to tv or dvd out of the jvc surround system?
  • 752 Answers
You will need a Digital Optical cable to hook it to the JVC. You should use a Component video cable to hook it to the TV.
Posted on Sep 11, 2007
I have the THC C-40 I am interested in purchasing another receiver from this line? Because my DVD tray isn't working on the current system so what other unit might I be able to connect the current...
The chances of another unit hooking to the current speakers is slim to none. While "home-theater-in-a-box" systems like that tend to be inexpensive, the drawback is that they are not compatible with other equipment. According to the Owners Manual, the ONLY unit they are compatible with is the JVC XV-THC50 or XV-THC60. Your best bet is to look for a new system that uses more standardized speakers (five 8 ohm speakers and a subwoofer that has an RCA style input and is powered by its own amp).
Jun 28, 2011 | JVC TH-C40 System
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
Apr 25, 2010 | Bose 3·2·1 II System
Want to listen to tv channels through home entertainment system
You need to get a 2 to 1 plug, that is, one will be connected to the earphone side of the TV and the other two will be connected to the Auxiliary or Video of your home system.
Check first, before going to buy so that you can get appropriate one.
Best wishes
Nov 12, 2009 | Audio Players & Recorders
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
Would like to listen to tv through the 5.1 speakers and don't know how to hook them up to do so, please help
You can run red and white from tv out to in on reciever, or optical out tfrom tv to in on reciever or digital coax audio from tv out to in on reciever, depending on which connections you have. then you would put your reciever on aux to hear tv through surround system. Also if you have a cable box or satellite box you can run the audio from that box to the input on surround system.
Hope this helps.
May 05, 2009 | JVC TH-G30 Theater System
Hooking up my ps3 to a all in one jvc home theatre system
Well I am assuming that you have a HD tv, If so than you can run HDMI from Ps3 to Tv then run optical audio wire from ps3 to reciever.To listen to ps3 turn reciever to aux setting.
Hope this helps
Apr 29, 2009 | JVC TH-G30 Theater System
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Arris DCT6200 DTV Receiver Logo
140 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
