Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Diagnostic test Error 000480
This is on a moultrie 4.0I
  • Moultrie Expert
  • 296 Answers
IT HAS FAILED THE CAMERA MOD TEST(4) COMMS ERROR UNDER MEMORY TEST(8)...THE ZEROS INDICATE ALL OTHER SYSTEMS OK
..but, other than deleting memory;opening battery swing-out door with cam on;turn off;close door; turn cam back on...this may or may not solve prob.
Ron L
Posted on Mar 14, 2010
Diagnostic error 2000
Moultrie liebherr diagnostic Digital Cameras Questions ...
www.fixya.com > Forum > Tags > liebherr diagnostic > Digital Cameras
Moultrie digital cameras liebherr diagnostic related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
moultrie diagnostic test error 000480 Digital Cameras ...
www.fixya.com > Forum > Tags > moultrie diagnostic test error 000480
Digital Cameras moultrie diagnostic test error 000480 questions and answers. Ask your moultrie ... ...moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Moultrie diagnostic code 12 Digital Cameras Questions ...
www.fixya.com > Forum > Tags > diagnostic code 12 > Digital Cameras
Moultrie digital cameras diagnostic code 12 related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Jan 20, 2016 | Cameras
I need a manual bar code on bottom of camera
http://images.ebsco.com/pob/Moultrie/catalog/DGS-D40-User-Manual-Compressed.pdf
Jun 30, 2011 | Moultrie D40 Digital Camera
Error code 000480, will not allow me to delete internal memory, says redo. is not recognized when it is connected to my laptop. brand new batteries & sandisk sd card. help!
Error code 000480="cam mod test/comm error...it is not communicating with SD card...may be bad main board ...get my parts from other defective cameras...Moultrie will tell you to buy new camera.
Jun 22, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a MFH-I-40 camera. The camera stopped taking images and is reporting Error # 20000. What is the problem?
Hi.
Moultrie error code 20000 means that your flash is not working. Moultrie will advise you to cover the day/nite sensor while running the diagnostic test.
Some people have fixed the error by removing the batteries while the camera is switched on and then reinserting them.
Regards.
Jun 08, 2011 | Moultrie Cameras
Moultrie game cam error code 1496 ?
this can't be an error code; error codes are in the format of 000000...100000=bat.test(0=pass;1=failed);020000=flash test/charging(0=pass;2=fail);003000=IR Sensor Test(0=pass;3=fail);000400=Camera Mod Test(0=pass;4-fail);000050=Memory Test.In this digit there are several codes...(0=memory ok/no sd card;5=memory full;6=SDcard locked;7=SDcard damaged;8= comms error)last digit,000006=Clock Test(0=pass;9=fail).
Are you sure this # is not preceeded by an "E", WOULD BE # OF EVENTS SINCE THEY WERE LAST CLEARED.
Ron L.
Jan 15, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Mode button does not toggle run options
make sure the on-off-aim switch is snapped onto the arm of the swich on the PCB
Dec 04, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie gamespyi40 error code 020000
I just spoke to the moultrie techy about the same error message I have with my i40, This is a false positive message, the i40 uses infra red instead of a flash; the self test is testing for flash and giving the false error. This was an oversight by Moultrie, no down-loadable patches are available to correct this at this time
Joseph
joseph@isportingworld.com
Jan 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
519 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
