Question about Ryobi 9 in. Benchtop Band Saw
Ryobi 9" bandsaw drive belt supplied by Ryobi is too small to get on the wheel even when warmed with a hair dryer
  • gamman May 19, 2009
    Ridiculous. Does Ryobi actually expect customers to 'poach' their wheel tires for 5-10 minutes?, then potentially burn themselves trying to fit them on?
    I received what look like 7-1/2 or 8" diameter tires for a 9" wheel. What's more, one of them appears to have a hole in it, as if stabbed from the edge. If I try to stretch this thing by that much, I just don't see it holding together.
    Lest I forget it's taken over a month to order these things in on back order from my local Ryobi service center, which is a 40 km drive one-way.
    I think I'm done with Ryobi tools, unless anyone has something a little more encouraging to say....
    GM
  • Robert Owen Nov 12, 2017
    I cut tyres out of old inner tubes
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I it myself by putting the band in a pan of boiling water. It had to stretch about 3". A hair dryer was useless to get it hot enough
Bob
Posted on Apr 13, 2009
I have a Ryobi bandsaw...model ebw 3523.....ryobi.eu tell me its obsolete so i cant get a replacement drive belt easily....none of the vintage sites ive looked on have even heard of it....Any ideas w
is this a 9 inch or 10 inch saw here is a link to thhe parts. also the same belt that fits sears or harbor freight will fit. they all have the same belt just made by different people. my sears an dewalt are the same part.
Ryobi BS1001SV 10 Band Saw Parts
Jan 31, 2015 | Ryobi Saws
I am unable to remove blade
Make sure you clean the knob adjustments on your bandsaw. Sawdust buildup would cause stiffness of the knobs. Look for a manual online and follow the instructions on installing band saw blade.
Jun 29, 2014 | Ridgid Ryobi Bs901 Band Saw Replacement...
Ryobi 902 bandsaw makes high pitch noise. have adjusted all guides and thrust bearing
The noise might not be coming from the blade, but perhaps from the bearings on the top or bottom wheel. Unplug it and open the covers. With the blade still on, turn the wheels by hand to see if you still get the noise. Then remove the blade and turn the wheels independently by hand. Then plug it back in and run the motor (with the blade still off!). Of course with the blade still off, the load on the wheel bearings will be very light, so maybe you can provide a bit of load by pressing a wheel or or caster against them as you turn them. Be careful. Good luck!
Oct 24, 2012 | Ryobi 9 in. Benchtop Band Saw
Broken drive belt on ryobi band saw, need
Just go to a well equipped hardware or auto parts store. Take the old belt with you so they can find an exact replacement. Good luck!
Apr 26, 2010 | Ryobi 9 in. Benchtop Band Saw
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Jun 28, 2009 | Ryobi 9 in. Benchtop Band Saw
Manual needed for Ryobi 9 inch Bandsaw - BS 900
Here is the ryobi tool website for your saw:
http://www.ryobitools.com/catalog/power_tools/band_saws/BS903#
In the lower left hand corner is a link to the manual (.pdf file)
May 29, 2009 | Ryobi 9 in. Benchtop Band Saw
I have a Ryobi 100mm bandsaw and would like to renew the rubbers on the wheels that the blade goes around could you put me in the direction as to where i could get them
Go to the Ryobi website and look under "support". They have a feature there that allows you to "locate a service center". Use that and you can find a repair depot that can supply you with the parts you need.
Apr 27, 2009 | Saws
Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
Jan 11, 2009 | Saws
Ryobi 9 in. Benchtop Band Saw Logo
508 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
