Question about Garden
Starter cord only pulls 1 foot
Starter only pulls 12'' then gets stuck.  There also appears to be no way to access the recoil mechanism to fix it.
  • COUGHY_MAN May 11, 2010
    what kind of engine is it? Briggs & Stratton or Tecumseh?
I have a brand new lawn mower from Home Depot with a Briggs & Stratton engine. I had the same problem when I pulled the cord. Heard a plastic on plastic knock after the cord was pulled one foot. I went to H D and we pulled a mower off the shelf so I could duplicate the problem. I removed the cord from the holder on the handle and allowed it to retract all the way to the engine. I pulled one foot and heard the same knock. It stumped three guys!
The fourth guy said we just weren't pulling hard enough. Pull until it catches and then give it a hard yank and it will start. I got home and pulled hard so that I could attach the cord to the loop on the handle. Once the cord was secure I gave it a good yank (making sure to hold in that choke bar) and it started on the first pull.
Classic operator error!
Posted on Jul 01, 2013
    Problem Solver:
  • 14 Answers
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Posted on Jun 19, 2009
My starter cord will only pull out about 6 inches and then it's stuck...
If the recoil will only pull out a little and it appears to be good when you removed it, then pull the plug on the engine and pull the recoil rope 3 times all the way. Important - watch the plug hole each time to see if black debris blows out. Then squirt 1 time WD40 in the cylinder head thru the plug hole. Clean, gap the plug or replace if required. LM19 I think, plug is marked. RE-install plug, attach laminator connector. Pull recoil rope again, should be free if engine isn't seized. Make sure oil has been changed this year, 30W, and is full. Check air filter also while you are doing this basic maintenance.
Jun 19, 2016 | Honda HRX217VKA Lawnmower
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Pull cord stuck open
Most likely the recoil spring broke. The engine cover has to be removed to repair this. If you are not mechanically inclined, it would be best to take it to a local small engine repair shop. Proper replacement involves knowing how many pre-wind rotations is required to properly recoil the rope. Some things are just better left to the pros.
Aug 23, 2014 | Garden
Fixing a cord recoil on a mtd mower with a 4 hp briggs and stratton engine
The upper covers and the fuel tank needs to come off, the starter on most engines is part of the engine cover so this will have to be un bolted and removed with the starter connected
May 30, 2013 | Mtd Garden
How to fit new starter cord
remove recoil cut off old rope take new rope burn end till pointy push threw recoil and into hole in pulley tie knot on pully side add handle pull string between pully and outer shell rotate pully counterclockwise 4 times with rope you puled from out in between pull access back out of the housing till tight release or go to a shop they normally only charge ten bucks
Mar 05, 2013 | Makita DPC6410 64cc 12" Power Cutter
Engine doesn't turn over pull cord stuck
remove the starter assembly and see if it is the recoil or engine. if by removing the recoil it recoils the cord then it is most likely a seized engine but pull the rope a few times with the assembly in your hand to check it then try turning the flywheel by hand and see what happens
Feb 09, 2013 | Garden
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
When I pull the pull cord on my snowblower it doesn seem to engage the starter. the cord retracts after I pull it. It was working fine when I used it yesterday, then today it doesn't seem to catch when I...
Hello, W/D here.
Most of the recoil starters have ball bearings in them, and the centrifugal force that you apply pushes the balls out where they engage pawls and allow the flywheel to be rotated. Since your's is on a snowblower, you may just be stuck, or moisture could be in the mechanism, freezing the ball bearings in place.
The quickest thing to try: Rap the recoil mechanism in the middle of the top, with a rubber hammer. You want to jolt it, without denting it. Try to pull the cord and see if it engages. You can repeat this several times, but try not to dent it.
If the machine is outside, and you believe that the mechanism may have frozen, you can apply heat to it with a hair dryer, and then rap and try.
Try these out and repost if the problem persists.
Best regards, W/D
Feb 03, 2011 | Garden
Garden Logo
628 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
