Question about Furuno GP31 GPS Receiver
Technical Manual of "MAGELLAN NAV1200XL"
I have MAGELLAN NAV1200XL, I need (6 Pin) power connector diagram. Please send us Technical Manual of "MAGELLAN NAV1200XL". How I get.
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
Mar 26, 2009 | Computers & Internet
Wiring harness on my 94 Ranger
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
May 30, 2008 | Car Audio & Video
Found power switch
Do you mean the pin set on the motherboard to connect your power on button's wires to?
This connector labeled: FPBUT_IN In Power switch connects to pin 6 and 8
Find Pin 1 and count down and then next row count down. Sounds like this connects to the second row and there should be no pin for pin location 7
This is the link to download the board PDF manual, go to page 78.
Your Motherboard has a different number assigned by Intell but is the same as yours.
Regards,
Worldvet
May 24, 2008 | Intel Motherboard
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Magellan Maestro 4040
hi ,
I understand from your mail that the power pin in the unit has been broken.
contact the Technical Support at 1-800-707-9971 so that they will give you a RA number and the address for the repair center.
Mar 07, 2008 | Magellan Maestro 4040 GPS Receiver
Jumper setting
You will need a manual for this board. There is no manual for USA. This link below is for euro.
http://www.giga-byte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1766
There are two power connectors. Both can be seen on pg. 6
Motherboard layout.
There is one ATX 20 pin connector just behind the Floppy drive cable connector. The second power connector is to the left of the CPU & down behind the intergrated USB. It is a 4-pin ATX_12volt connector. If either one is not connected correctly the moard will not boot. The case to motherboard connectors is located on
pg.15. F_Panel (2x10 pins Connector) & PWR_LED = (Power LED) for case.
Please use the manual as your guide.
& please vote...
Feb 23, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
Furuno GP31 GPS Receiver Logo
97 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
