Question about Jabra BT350 Bluetooth Headset Headset
How to put in discovery mode for bt350 jabra blue
How to put in discovery mode for bt350 jabra blue tooth
3 Suggested Answers
  • 13 Answers
SOURCE: jabra BT350 bluetooth
While the headsetis off, press and hold the power button for 6 seconds. It will first blick the light in several patterns, all in blue. Finally, it will come on solid blue, no blinking. It is now ready to be paired. Once your phone/PDA has detected it, the passkey /should/ be 0000, as in zero zero zero zero. That should do it. Best of luck! :-D
Posted on Jul 15, 2009
  • 638 Answers
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra BT3030 Bluetooth Headset
I have a jabra bluetooth how o i connect to my phone
You need to put the bluetooth device in discover mode, then on the cell phone, you configure the blue tooth settings to "find" the bluetooth headset. Check out this document on how to pair a Jabra (may not be your model, but bet it is the same process). Good Luck!!
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Oct 17, 2010 | Cell Phones
Discovery mode
If you mean pairing, then hold the button down until both red & blue lights flash. If your bluetooth transmitter is in paring mode too, it will connect up. Note that the headset must be off before you begin.
Mar 20, 2010 | Jabra BT350 Bluetooth Headset Headset
I dont know how to pair my jabra bt350 with my lg dare from verizon
hello mom. try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Jan 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra VBT2050 Not detecting
On The Blue Tooth You Have To Hold The On Off Till The Light Flash's Blue Red Over And Over Then Search For It On Your Phone.
Once You Find It It Will Be Recognized For Now On. Just Hit The Button On The Blue Tooth One More Time To Stop The Sync Mode.
Jan 19, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 bluetooth
Mar 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
447 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
