Question about LG 42LG50 42 in. LCD HDTV
Remote not recognized by TV. Brand new model.
Remote not recognized by TV. Brand new model. Batteries are in correct and remote lights up but does not work with TV
  • neal36 Apr 16, 2009
    Exact same problem. TV is about 3-4 months old. Replaced remote batteries, and TV just isn't recognizing it.
  • 87 Answers
An easy way to tell if the remote is bad or not and I know this sounds funny. Put the remote next to a small am radio tuned off a station if you hear a pulse when you press the buttons on remote it is ok 95 % of the time. If this set is new just simply call LG or get an authorized service center to replace IR sensor in TV.
Posted on Apr 12, 2009
My magnavox remote is not being recognized by tv it came with. How do I fix this issue.
Try replacing batteries but the remote control may have simply failed.
Oct 03, 2017 | Magnavox Televison & Video
Hisense TV, remote keeps using up my batteries, only last a week or two.
seen this battery issue reported online before with these remotes
depending on age and model of that TV
you can buy new original ones
dont buy universal types for a hisense
is it the original remote ?
what brand of batteries
lithium energizer?
info
rechargeable batteries never fully charge up
only two needed
size is AAA or AA
Oct 23, 2016 | Cars & Trucks
I got a replacement remote for the TV but it doesn't work on the TV. How do I get it to function with the TV
When you say "Replacement" you do not say if you bought an "Original type" replacement or one of those Universal ones which may or may not have the correct codes for the TV in question. Not all Universals have ALL POSSIBLE CODES.
You have two options.
1. Have your TV checked to find out if it is capable of responding to a remote control. If it won't then no remote whatsoever will make it respond ! Remote Receiving circuits fail as well !
2. If it is OK in that regard, get an original brand replacement Remote Control.
You can buy a Remote Control tester or you can take it to a TV technician who can check for you if the Remote is working.
Be sure to double check that you are using NEW batteries and that they are put into the remote with battery polarity as marked. You would be amazed how many times I have found that the problem was caused by persons putting batteries in the wrong way round !
Because of the shape of the ends of them, with some rechargeable batteries it is not so immediately obvious at to which is + and which is - unless you look very closely at the battery markings.
Jul 08, 2015 | Mintek DTV-323 32 in. LCD TV/DVD Combo
The wii console is not recognizeing the remote. Batteries are working fine. Theblue lights light up. None of the buttons are stiff or overly loose. Brand new remote
try and calibrate the remotes by pressing the red button on the console(its next to the sd card slot) and press the red button on the remote which is were the batteries are
Jun 06, 2010 | Nintendo Wii Console
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
I have this item and the batteries are brand new and installed the correct way. It just does not work.
You can test to see if your remote is actually putiing out signal, just point the remote at the digital camera, you should see flashing light on your camera screen when you push any buttons on the remote, if you do see the light, then the problem will be in the remote receiver in the TV itself.
Dec 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Remote works sometime but not always
1. replace with fresh alkyline batteries.
2. If you have fluorescent lights, they will interfere with the remote.
3. Turn OFF lights, remote will work. Turn ON lights, the remote may not work well.
The "code" depends on the Remote brand/model.
Different maufacturers of remote control units don't use the same code numbers (there is no standard remote code for any TV).
Hope this helps!
Sep 08, 2009 | Sanyo DS27510 27" TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
LG 42LG50 42 in. LCD HDTV Logo
196 people viewed this question
Computer Repairing
Computer Repairing
