Question about Dometic Rooftop RV Air Conditioner
The dometic a/c's on my RV are not working. I have had in to a dealer many times. they have to take the covers off and put silicon on the shafts, bu doing that one works for a few days and the other one works until I shut it off and then the problem starts all over. Has their been a recall on these? they are on a 2005 Georgie Boy Landau with 15,000 miles on it. i have owned it since new. please help.
    Guru:
  • 587 Answers
If they are putting silicon on the motor shafts or bearings and the motors start working, then the bearings in the motors are dry or bad and the motors need to be replaced. The silicon will lubricate the bearings for a little while and that's why they will work for a while.
Posted on Apr 13, 2009
Sounds like fan is clicking on roof top dometic RV ac unit, but fan is not hitting anything.
check fan shaft and blade to make sure mud dober or mouse didn't build nest in there. if they did remove it and see if it works.
May 30, 2015 | Dometic Rooftop RV Air Conditioner
Where can I find a replacement shroud for my dometic roof top A/C?
Try any local RV dealer, camping world, etc , or call 1-800-544-4881 to order directly from Dometic.
This link will take you to a dealer locator for your info on dealers in your area.( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ ). Have your model number ready. Most dealers may even have a used one to sell you if you ask.
Sep 29, 2011 | Dometic Rooftop RV Air Conditioner
We have a Dometic Duo Therm airconditioner on our RV. The model number is 620515.331. When I climbed up on the step ladder to have a look at the roof of the coach, I noticed that encircling the unit,...
Yes once you remove the screws the shroud should come right off. The cover is just that, the cover for the unit. You might think about putting some screening around the opening to keep this material out.
May 29, 2011 | Dometic Rooftop RV Air Conditioner
Leaks inside when running
you might have a drain line plugged up...or a dirty evap coil...call if you need direction an what to look for...
May 12, 2010 | Dometic Rooftop RV Air Conditioner
Where can i find a relay for the fan motor on my dometic unit? part #- 3ARR3B3TP3
Go to this link, (dometic,) and select area etc, for dealer who should have parts for that.
http://www.rv.com/vendors/default.aspx?F_State=
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
Coleman RV Roof AC Fan Issues
It sounds like you have a bad fan capacitor.
You might try replacing it, they don't cost very much.
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Fan blades on dometic brisk air needs to be replaced
Roof top cover will have to come off, to get accesss to it. Not too hard to do, but may want to spray shaft in area of blade with WD_40 or similar to remove rust , and make on & off easier. Here's a link to dealer locator for Dometic. Any dealer should be able to get you a new one pretty quick, or most even have used ones from units previously removed from RV's if your stuck. ( http://www.dometic.com/enus/Americas/USA/Customer-Support/Dealer-Locator/ )
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm RV Air Condiioner-Compressor comes on before fan motor
I'd have someone who's familiar with capacitors, (for safety sake), to test your fan run capacitor, and power to it. If capacitor is shot, fan won't start. Have to remove cover on upper unit, then cover on side at front where wiring is, to access it.
Jul 11, 2009 | Dometic Rooftop RV Air Conditioner
I have just purchased a new carrier low profile 15,000 unit
is their air flow threw the condenser? with the cover on sounds like its cutting off on high pressure switch restricted air flow.
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
193 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
