Question about HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107
Need recent motherboard schematic for reference
I am trying to fix some fairly new mother boards. I could use a schematic of almost any recent motherboard. I mostly need the cpu power circuits.
I found a reference to one on your site but it no longer worked.
Thanks in advanced.
The CPU power circuits for the PCChips A15G motherboard CPU AM2/AM2+ are in two (2) locations on the motherboard. The 24 pin is located near the 40 pin IDE Channel (right edge), and the 4 pin is located near the CPU/heatsink/fan (upper midway).
Posted on Apr 14, 2009
Schematic
You have not included necessary info such as brand and model.
You will also never get a 'schematic' for any mother board, only a board layout and specifications since a true schematic would cover an average wall.
Oct 23, 2014 | Computers & Internet
Msi motherboard p4m900m2
after fixing a new mother board u must reinstall your operating system. the driver settings change for each mother board
Dec 24, 2007 | Intel Motherboard
I don't know what motherboard it is that i have to download the users manual can you please.....please help me
Turn off the PC. Remove the side panel from the case. Get a flashlight and inspect the mother board. You're looking for a number to identify the type of mother board. ASUS mother boards usually place this number just to the left of the memory slots. It's usually 5 or 6 digit long and made up of both letters and numbers. One of my computers with a ASUS mother board is a P5LD2. Once you know this number you can go to http://support.asus.com/ and download updated drivers for *********** board. You may need to identify what type of socket *********** has. If you have a fairly recent Intel microprocessor you probably have a socket 775 mother board. If it's an AMD microprocessor it's probably a SocketAM2 or AM3. You might have to do some searching if these choices don't work. I hope this advice helps you out.
Jan 28, 2011 | ASUS Computers & Internet
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
I LOST MY MOTHER BOARD CD
hi there
please try to contact the manufacture of the motherboard they should be able to help you or give you the right information that you need.
Mar 11, 2009 | Intel Celeron -D 2.26Ghz Computer System...
Motherboard for IBM Netvista shot.
If the 200 dollars is for the board only they are probably fairly accurate. If this includes them installing the motherboard, that is very good. As long as the memory fee isn't too much more, this wouldn't be that bad of a deal. If you are planning to fix it, yes, you can find a new mother board. There are plenty of computer hardware dealers out there. If you can't let me know exactly what board you need and I will look as well. As far as the memory transfer, the only thing I can think of is cached memory or informaton stored on chips that was put there by the manufacturer. As far as a good price for that, I am not sure. If there is anything else I can do for you, rate this solution and post what you need to know as a comment under your lising and I will try to get back to you as soon as possible. I hope this is helpful.
Nov 11, 2008 | IBM NetVista PC Desktop
Mother board driver problem...
You will need to open the computer case and look for the model number on the motherboard. Usually it will be in bigger font than other text. When you find it, you will need to search google for that model number and get the drivers from the manufacturer website and install them.
Oct 27, 2008 | ASUS K8V-MX Motherboard
NO BIOS
to get bios set up you must press DELETE key or F2 to enter set up...
you do this at the time of the booting ....
if your bios is corrupted then you can restore the bios by changing the bios jumper to restoration mode to do this refer to your motherboard manual...
Feb 22, 2008 | Intel Motherboard
Trying to put a mother board together need help
Hi LadyT18,
Apparently your power supply is an ATX 20-pin type (v1.x) and is the standard a year or 2 back. Your motherboard being fairly recent uses the new standard which is ATX1 24-pin type (v2.x).
Your options are:
1. Replace your power supply with a higher wattage/XX pin;
2. You may still use the old 20-pin power supply provided that it is rated 300 watts or higher. Additionally, please bear in mind that using a 20-pin PSU to an ATX1 (24pin) may cause boot failure and/or instability during operation due to insufficient power delivery.
I scanned part of a motherboard's manual to illustrate how this could be done. Below is the image for your reference.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Biostar : I945P-A7...
HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107 Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
