Question about Kenmore 74962 Gas Dryer
Roper gas dryer not heating
I have a roper gas dryer that is not heating up . the thermal fuse is good and the glow plug lights but i cant see if the whole thig lights up . the dryer really squeeks bad . I would like to oil or grease it and replace the glow plug , how do i open it up and do you think its the glow plug
  • bano Sep 13, 2007
    big help , that you , it was the coils
  • dave1234 Jan 03, 2008
    gasnot coming on
  • 60 Answers
The glow plug (ignitor)must draw 3 amps or more to function properly if its ok check the flame sensor for continuity located on the side of the burner housing and if its ok then the gas coils on the top of the gas valve are faulty let me know if this helps
Posted on Sep 12, 2007
I have a Roper gas dryer model #RGD4640YQ2 and the product will turn on but will not heat up. As far as I can tell the gas line is fine and getting gas to the dryer. Please advise
There are three main culprits that could be your problem: Unplug your dryer and first, check the thermal fuse located on the blower assembly. It's about an inch long, white plastic piece that has two terminals sticking up. Disconnect one of the leads to it and use an ohmeter to check continuity. It should read a short if it's good. If that's not it, hook the lead back up that you took off to test the thermal fuse, plug your dryer back into the outlet and turn on your dryer and watch your glow bar. It should glow brightly. If it doesn't, then replace the glow bar. If it does glow brightly, but you still aren't getting any flame, replace the gas valve coils. If, that doesn't do it, then the final most likely culprit is the flame sensor (also called a "radiant sensor").
Oct 18, 2014 | Dryers
Roper gas dryer does not ignite.
The problem is the ignitor...
Check out this tip that I wrote about that problem...
Apr 07, 2010 | Dryers
I have a 6yro roper gas dryer. model : rgx5634kq2 everything works except it wont heat up ignitor is good as well as thermal fuse
Hello, If your igniter is glowing does not mean it's good, Take a look at it while it is glowing..Is it orange in color..Uneven glow? then it's bad...the igniter needs to be pulling 3.5 amps in order for a) the gas valve to open B) gas to ignite once gas valve opens. The glow should be a brillient yellow that you find hard to look at. If the igniter is bad the only other possibilty is the flame sensor. It is the gadget hooked to the side of the tube where the flame is. Using an ohms meter disconnect the 2 wires from the terminals and check for condinuity..If you have no reading (condinuity) you should replace it. Good Luck!!! If you have any other questions or concerns please feel free to comment again. Mike
Jul 23, 2009 | Roper Dryers
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Gas dryer not heating
Jan 13, 2009 | Roper RGS7646KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryer wont heat
ck whiten thermal fuse on blkower housing of dryer may be behind back panel..if fuse of ck the flame sensor with volt ohm meter should show a complete circuit..or just jump it out in any case should be 110volts fed to connector going to valve ..also may be bad ignitor (glow plug)may show burnt spot
Sep 18, 2008 | Roper RGX4634KQ Gas Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Kenmore 74962 Gas Dryer Logo
173 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
