Question about Dryers
Unexpectedly stops Dryer begins cycle, then after a while buzzes and stops - won't restart until it's cooled down. Frigidaire fsg446rhs gas dryer. Motor, thermostat, or ??? Any ideas?
  • Dryers Master
  • 3,361 Answers
Lighten the loads.
Clean the lint from around and in the motor.
Replace the belt.
Check the rear drum support and front support guides.
If that does not correct the problem you have a bad motor.
Posted on Apr 12, 2009
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
I have a Frigidaire gas dryer and it ingites and works but with in a minutes the gas is cut off and never ingites back.
On your gas valve , there are 2 coils . Replace both as they come together . When they get warm due to electricity going thru them , one of them will open ( short ) and not let gas come thru until it's cooled down . Turning the dryer back on later , it will work for a short time , then stop heating again until the dryer is cooled back down. Replaceing these coils will solve your problem .
May 16, 2010 | Frigidaire GLGR331A Gas Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Whirlpool dryer makes buzzing sound when flame should start.
Sounds like the valve is trying to open and the buzzing is the restriction of it opening. Coil is obviously correct, but actual solonoid is sticking. Replace it and see. If flame isnt detected, it will stop.
Sep 21, 2009 | Dryers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
