Question about Vacuums
Need directions for changine belt for brushes
I HAVE A BISSEL SHAMPOOER PRO HEATTURBO I NEED DIRECTIONS ON REPLACEING THE BELT FOR THE BRUSHES
  • Anonymous May 08, 2009
    JT.... you are talking about the pump belt. There are 2 belts. One for the pump another to turn the brush, I can feel the one for the brush, just can not get to it.
    Any help out there?
On a 7901, after your remove the side access door you turn the machine upside down, find a red plastic retainer held in with a phillips screw. Remove the screw and carefully pull out the retainer. The beater bar will become loose. The beater bar is driven by a toothed belt. Remove a cover over the belt and then the toothed belt.... Now install the new pump belt. Reverse the procedure and you're good to go.
Posted on Apr 22, 2009
  • 61 Answers
There is a door on the side pop it off remove the old belt and simply slide the new belt on. Over the motor shaft first then the roller brush end.
Posted on Apr 15, 2009
How to get the beater brushes to work
Your belt is broken or has come off the track.
Mar 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro heat unit brushes will not engage
keep in mind they only turn when the handle is down. if that is not the problem, it is usually the belt.
David
May 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cant put belt on {goes to brushes}
bo to bissell.com and go to tech support maybe you can find it there,or just type the brand and model number followed by manual in your search browser and you will find all kins of places you can get it
Apr 13, 2009 | Vacuums
Bissel pro heat /brushes do not turn
Belt worn or hair build up can clog it from spinning. I've seen this on other models. Just remove the hair slowly. If the Belt is worn you can replace that from Bissel or any store that sells their product.
Check to ensure that the pump belt and brush belt are intact and installed according to the instructions provided in the User's Guide.
The pump belt is located under the belt access door on the side of the machine. This belt should be looped around the red pulley and the silver motor shaft.
To check the brush belt, please follow these directions:
Turn the machine OFF and unplug from the wall outlet.
Step on the handle release pedal to lay the handle down on the floor.
Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
Turn the machine over to expose the brush.
Look for the red retainer plates, which hold the black brush arms in place. Remove the two Phillips head screws to access the toothed brush belt. Check to ensure the belt is intact and looped around the brush end, as well as the red pulley with the ridges.
Remove any dirt or debris from the brush assembly.
Inspect brush, brush arms, red brush arm retainers and red pulley for damage and replace parts if applicable.
Jul 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
My bissel pro heat cleane's brushes stoped. I checked the belts. They are okay. There is no sign of heat or problems around the motor. Is there a mercury switch some where in the handle so the brushes...
Depending on which model you have, you did not say, if the cogged belt goes to the pump pulley, the cogs may be wore away or and won't turn the brush roll. On some other moels, there is a brush roll motor that may have gone bad.
Apr 17, 2008 | Vacuums
Vacuums Logo
138 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
