Question about Air Tools & Compressors
No air pressure!
Hi: I own a Husky air compressor. It's a 4 gallon 'doughnut' tank type. All of a sudden it doesn't hold any air: the motor runs forever but there is no indication on the meters of any air pressure. Can thos be fixed or should I invest in another? Thanks!
  • draahobbs Apr 13, 2009
    Thanks for your quick reply.
  • 50 Answers
There are "0" rings in the compressor, if the compressor is less than $200 it's a "throw away". it can be repaired but usually not worth it
Posted on Apr 13, 2009
Air compressor cannot spin up with pressure in tank sometimes
There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Q26 will not build pressure. Where do I buy parts?
First check the check valve and also if it has an unloader valve make sure it is closing.
The main check valve is often right where the air goes into the tank. The unloader can be integral to the pressure switch or on the compressor.
Sep 26, 2009 | Air Tools & Compressors
Husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Sep 03, 2009 | Air Tools & Compressors
Husky 1.5 HP 6 gallon compressor motor runs but does not build up any pressure. Unit is only 2 years old and is only occassionally used to air up my car tires.
Your manual pressure release valve might be stuck open or blocked open by some debree. It should have a steel pull ring on the end of it. Exercise it and try running it again. Also the pressure regulator adjustment might have been backed off to zero. Crank it clockwise and see if this helps. Check the air output lines from the compressor to the tank for leaks.
Jun 18, 2009 | Air Tools & Compressors
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
323 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
