Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The door flops open as the rope has broken. I have the replacement part but need a diagram to show how to replace the part. Where can i find the diagram?
  • 1 more comment
  • Anonymous May 05, 2009
    The door flops open - the rope must be broke or the spring?
  • missyt123 May 13, 2009
    Same exact problem....just happened for the THIRD time. Our original contractor has sent a tech out the two previous times to repair (?). Waiting to hear back from them now on the most recent occurance.
  • jb8321 May 14, 2009
    The door flops open. The string is broken on one side. Anyone have the part number for the rope.
Documented in the manual...The plastic part goes on the metal hinge on the door...follow the rope down to the top wheel (clockwise and around) to the bottom wheel (counterclockwise and around), attach to the spring.
Posted on Apr 16, 2009
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
Door spring rope broke on door , door falls when opened like to fix it need part and diagram of unit
http://www.bosch-eshop.com - enter the correct model number: SHE43P05UC in the search box on the right side, select which dishwasher you have from the results list. Click on the number of the part you need, it should show the manuf. par number on bottom.
or go to http://www.searspartsdirect.com and check there.
Once you get the manufacturer's part numbers - go to http://www.repairclinic.com - they have pictures of most parts.
Vlad,
First Choice Appliance, Sacramento
Jul 06, 2012 | Bosch Dishwashers
Dishwasher door flopped open and now the door will not hold. I called a repairman and he said he could fix the door but it may not hold. My exact model number is KUD101FLB5. thank you.
Hello, Welcome to Fixya.
Based on your description what you`ve likey experienced is a broken door closer/link kit.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit, and check the spring itself...that is seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Aug 02, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and break.it is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the unit.buy the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 | Dishwashers
Adjusting the start handle
After I get the rope rewound on the spool, I place the spool in the housing pull about 2 inches of rope through the slot in spool and rope end will be facing you. Then wind the spring by turning the spool in the same direction that you would pull to start. Then thread the rope through the starter housing and then tighten keeper that holds the spool in place. If is still will not keep tension, your spring is probably broken.
Apr 11, 2009 | Homelite Garden
Door broke
Pick up some nylon rope (same diameter or slightly larger) at any home store such as Home Depot, Lowes etc.. Need to attach the original plastic ends to your new nylon rope as well as to the door spring and then re-install on the bottom side of the door. Hopefully the other rope for the door assist is still intact so you can use that side as a guide as to how to route it around the pulley. Make sure that you lube the new rope up with some Vaseline etc. My door was squeaking very bad. Seems that the rope dries out over time which could have possibly caused your to snap. Pretty bad when your $1200 dishwasher door uses a length of small diameter rope to keep your door loaded with sensitive electronic boards from crashing to the floor!!!
Mar 05, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
Door slams down
you need to replace the link assemble. is should come with a rope looking thing and wheels/ pulleys.
Jan 04, 2009 | Dishwashers
Door drops when opened
your door's hinge link is broken
Pull your dishwasher from under counter (you may need to disconnect hoses and power connnections, so turn off power at the circuit breaker). Look for the broken rope-like item and replace it. Use the other side as an example on how to re-install the link. Attach link to spring, hook spring back into frame/chassis, threaded link through pulleys, attach other end of link onto door then reinstall dishwasher under counter. My replacement link package came as a pair, so replace both at the same time. The other side may still be attached and functioning, but will most likely show signs of wear.
Dec 13, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Rear driver side window
HAVE YOU REPLACED LATCH? IF SO YOU NEED TO ADJUST
Aug 27, 2008 | 2003 Kia Sedona
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
845 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
