Question about Canon imageRUNNER 400S Copier
IR400 black copy
  • Anonymous Apr 28, 2008
    i have plan to buy canon ir400 i would like to ask your expertise what is the common problem of this unit
    thank you very much
  • 24 Answers
Check exposure lamp
Posted on Sep 14, 2007
Canon IR400 print copy to black print
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
Canon IR400 mechine print to black copy
IR400 copier print to black copy
Not at all certain what your question refers to. The Hp Image Runner 400 is a black & white copier. What do you want to do that you are unable to do? Have you previously been able to do what you wanted with this copier, but can no longer do the same? What happens when you try to copy a document? Does the copy come out blank, or all black? Are you getting a large black area on a 8.5 x 11 inch sheet of copy paper when you attempt to copy something that is smaller in size, and therefore wasting lots of toner? Please explain your problem in detail, or no one will be able to help you. Thanks
Nov 24, 2014 | HP Office Equipment & Supplies
IR 400 NO ERROR BUT PRINT FULL BLACK COPY with out print
how make copy more dark by using additional function in ir400
Oct 13, 2010 | Canon imageRUNNER 400S Copier
Sir, I am having IR400, the copy became white coloured font with very dark black background, so i replaced drum & blade and then copies became normal, but very light, then i increase the density from 5...
Why did you do ccd-adj before cleaning the optics?
in copiers front door must be sheet with numbers that are factory input, do the clear all, and then set the values from paper in service mode.
May 18, 2010 | Canon imageRUNNER 400S Copier
How to Find Canon iR400 Total Copies Volume
there are two types of counter : mechanical total counter is infront of the machine just open the frontdoor cover its on the left side if there is 3 counter , the topmost counter is the total.
if you want to see the e-counter press *(with head)> 2&8 at the same time then* (with head)the display will change press COPIER>COUNTER you will see all the counter, usually this counter does not match with the mechanical one
Jul 12, 2009 | Canon imageRUNNER 3035 Black and White...
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
IR400 ERROR CODE E014,E806
E-014 - The fixing motor has a problem. This can be the fuser drive motor, DC Controller, or Image Processor circuit boards. The only time I've had this problem is with one of the fuser bearing going bad and causing excess drag to the motor, giving you the error. See if the green fuser advance knob is hard to turn. If so then check the bearings.
E806 - This is not in the book that I have. Be sure of the number.
E-805 - There is a fault with fuser cooling fans ( located on the delivery door )
Nov 20, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
Clive
Clive
old marine
old marine
