Question about Samsung PCJ522R 52" Rear Projection Television
Picture gets red, and shadowy.
Picture has red shadows. After about an hour of being on it went away. however it came back. it seems to be in and out all the time. Sometimes it seems like it gets a second picture about an inch below so if you look at a face it looks as if they have four eyes. Any ideas ?
  • benwells Sep 11, 2007
    Is that expensive if its convergaence ?
Complete convergence job usually a few hundred buck$
Posted on Sep 12, 2007
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Sounds like a convergence issue. the conv. amps may need replacement. it.s best to hire a tv guy to make proper diagonostics and repairs.
Posted on Sep 11, 2007
Shadowing of picture
A shadowy or 3D image is caused by the convergence not being aligned. If your model has a convergence menu goto it and see if you can adjust the colors so that they are all straight and aligned. If so the 3d shadows will go away. If however it wont adjust the convergence has failed and would need to be to repair the TV yourself or with a company. Convergence repairs are common a fairly easy DIY fix.
Apr 20, 2013 | Mitsubishi WS-55819 55" Rear Projection...
Plasma TV gave pop sound and no pictures except very dark shadows almost not visible
the back light went out the pop was either a capacitor aor a fuse blowing seeingas you sill have a shadowy picture it would most likely be the capacitor for the back light supply. Most repair shops should be able to replace the capacitor for you or if you feel like doing it yourself you willneed a soldering iron, solder, de-soldering iron or simialr, the repalcement part. to locate the blown capacitor just look for a burn part on the board.
Jun 30, 2011 | Televison & Video
I have a toshiba model 57hdx82. It has a shadowy
You have a cinversion problem you can purchase kits and do it yourself or send it in to be done average cost og repair 280-320
Apr 27, 2010 | Toshiba 57HX81 57" Rear Projection...
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Apr 13, 2010 | Televison & Video
My toshiba tv has shadowy streaks on the screen what is the problem
If your TV is a old picture tube technology type try the following.
The following is for technical experts only
It is EHT cable contact problem.
Switch off TV. Remove all electrical wire connections including antenna cable etc.
Wait for few hours! Open the back cover. You will find a thick red colored cable connected to the picture tube through a suction rubber cup. Ease the rubber and slightly rotate it. Very little only. This will establish a new contact in the picture tube shell. Place the rubber cup in the same way. This just a suction cup and hugs the picture body and air tight.
Now switch ON try. If OK leave it. If not try the same way of waiting.
Failing to observe the cooling period,
You are likely to get High Voltage electric shock as picture tube acts as a storage current for few hours. ( Even switch is OFF )
Mar 30, 2010 | Televison & Video
The visual screws up when i play games with shadows
haha, you're gonna get sucked into the matrix
but, mine did this, then the picture went, so try a new av scart, or look up the fixing problems for no picture, and try to fix it before it breaks
Feb 22, 2009 | Microsoft Xbox 360 Console
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Hardly any Blue Color in the picture. the blue tube is projecting darker and dimmer.
You need a Blue picture tube CRT you can get one for your JVC at the following link for a real decent price and they provide free shipping. Heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
GE Television Dark Shadows
If you are comfortable working inside the set, I can suggest the following:
1) Open up the back and locate the flyback transformer (part with large red wire coming out the top). There should be 2 adjustment posts on the back of it.
2) adjust the top one slightly clockwise as you are facing ht back of the TV. This should cause the overall picture to brighten. Don't turn it too much as you will then see the "retrace" lines.
3) Adjust the lower one to focus the picture.
That should help a bit. If not, then the picture tube is probably at the end of its life. Keep me posted with your results.
Dan
May 24, 2008 | Televison & Video
Samsung PCJ522R 52" Rear Projection Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
