Question about Kitchen Ranges
Oven dont work
The oven part of the stove is not working
Is it gas or electric?
Posted on Apr 12, 2009
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
Stove Manuals. My electric cooker is named STOVES 720ef. I dont know how to work it
You're in luck.
I have just uploaded a scanned copy of the manual to the link below.
Requires an Adobe Acrobat reader to view the manual which most computers have.
This address is below:-
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Please share this file with others who need it.
Kind Regards,
Simon
Oct 28, 2011 | Stoves 720EF Electric Double Oven
Door to oven locked wont open
u can try unplugging the range for five min , if that dont work , get its electrical checked out
Apr 21, 2010 | Kitchen Ranges
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven doesnt work
If it is a fan assisted model, check that the fan blades are not catching the back panel in the oven itself, the fan mat be worn or the blade loose or bent.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Ovens
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Creda Concept Superglow Stove
I fiddled with the buttons until the oven came on. Dont know which buttons but working now. Thnx
Jul 18, 2008 | Ovens
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
