Trying to connect the two using 4-pin s-video cable
I have an 4 pin s-video cable but my laptop has 7 pins and the tv has 4. do i plug it in the monitor out input or any input?
  • armani_mcgow Apr 12, 2009
    where do i connect the cable in regular input1 or monitor out and what do i do on the computer
    President:
  • 948 Answers
You can use the four pin male S-video cable on a 7-pin female, the picture quality just won't be quite as good.
Please rate this solution a FixYa.
Posted on Apr 12, 2009
  • Dick
    Dick Apr 12, 2009
    I'm not sure what you are asking. Break it down into smaller tasks. You have an S-video cable.
    You have a laptop with some output ports.
    It is highly unlikely that you have more than one S-video port on your laptop.
    You have a TV with some input ports.
    You could have S-video inputs on several places, it doesn't matter which one you choose.
How could i connect this tv to laptop
Connect by this way:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Sep 16, 2010 | Samsung CW29M64NS 29" TV
S-video pins?
Hi there. You can try to purchase a 7-pin S-video-to-RCA adapter/dongle.
check this website to see what I am trying to point out.
http://www.amazon.com/7-Pin-Mini-DIN-S-Video-Female-Cable/dp/B002W81MO6
Hope you can make it work!!! ^_^
Jun 03, 2010 | Dell Inspiron 1525 Notebook
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
No audio when connecting Aspire 5315-2326 to TV.
Use a cable out of the headphone jack with an adapter to the red and white (left and right) audio jacks of your TV.
May 16, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
I have a hp pavilion ze5000s laptop with a 7 pin s-video port, I also have a flat screen tv with a 4 pin s-video I am trying to use my flat screen as my primary monitor my question is can I use my 4-pin...
you might try a 4pin cable and see if it works.
Not all pins are needed to provide a signal.
If the cable dosnt fit the computer it might be that the Svid port on the computer is actually a Dongle port requiring an additional dongle before the video cable plugs into it.
Mar 16, 2009 | HP Computers & Internet
7pin s-video to 4pin s-video
you have to have and adapter for it. it changes it from a 7 pin to a 4 pin so that your cable can connect to the tv.
not sure how much they are worth but they shouldnt be to much.
hope it works for ya.
Notebook connection to tv
S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
Dec 26, 2008 | HP Pavilion dv6000z Notebook
Connecting my laptop to my Samsung DNie 29' Tv
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Aug 14, 2008 | Dell Latitude D600 Notebook
No display on tv
"please email me for further help if this dosn't help before you mark not helpful vicer@comcast.net"
first try updating your drivers at www.ati.com, I have to ask you to double check the connector your using to goto the tv, if your using a S-video cable check the port on the card your connecting to, if there are more then 4 pin holes in the connector you need a pigtail to connect to your tv, many video cards use a cable that is sold seperatly to connect to a tv, connector look like a s-video connector and a s-video cable will plug into it, but instead of 4 pin holes it has 7, 9, or 12 connectors depending on the card, and the type of output the cable has. most are 9 pin with composit, s-video, and componite connectors on them.
May 09, 2008 | VisionTek 7K RADEON 7000, (64 MB) Graphic...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
