Question about Samsung HLN617W 61" Rear Projection HDTV
TV will not turn on
If power is disconnected then reconnected, the TV will turn on for about 10 to 20 seconds. Then it will turn of and there will be three blinking lights on the front. It can not be re-turned on again until power is disconnected. Is this something I can try and fix myself?
  • Anonymous Nov 02, 2007
  • Anonymous Feb 15, 2008
    TV won't turn on and there are no lights on the fron LED indicator
  • 1,284 Answers
Try replacing the lamp. It os the most likely cause.
Posted on Jan 24, 2008
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings:
Hopefully this post helps you! If does, please mark it "accept as solution"
Aug 20, 2017 | Sony Televison & Video
My Netflix works up until I press OK, then screen goes black. Thankyou.
Restart the smart TV
Press and hold the power button on the TV remote control for 10 seconds to restart the TV.
If you restart the TV, try Netflix again.
If the TV does not restart, turn it on again and continue with the following troubleshooting steps.
Disconnect the TV from the power for at least 1 minute.
With the TV off, press and hold the power button on the TV for 5 seconds to unload it.
If you can not access the power button or your TV does not have it, leave the TV off for at least 3 minutes.
Reconnect the TV.
Turn on the tv.
Try Netflix again.
Aug 12, 2017 | Cars & Trucks
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Menu keeps popping up ever few seconds, wont go away.
Check and replace the main system control memory IC. It is faulty.
Feb 11, 2013 | Toshiba 35A44 35" TV
Sharp aquos 65- we have sound but no picture. What do I do?
There has been a power supply failure. The process of disconnecting then reconnecting the TV shocked the failing power supply back to life but ultimately it failed
Jan 29, 2013 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Have power but wont turn on
Disconnect the power cable from the TV and then press and hold the power button on the TV for 25 seconds. Now, reconnect the power cable and then try to turn it on.
May 28, 2012 | Computers & Internet
Disconnect all the cables from the TV including the power cable then press and hold the power button on the TV for 30 seconds.
Next, reconnect the power cord and other cables and try to turn it ON.
Good luck!!!!!!!!!!!!!!!!!!!!!!!!
Sep 28, 2009 | Protron PLTV-32 Television
No powering on
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Aug 24, 2009 | Dell Computers & Internet
After turning zenieth tv on for a few seconds a black screen coves the screen and picture will re apper if you change channels. then it repeats
I found an answer to the problem on which was to disconnect TV power cord for 4 hours, then reconnect. It worked!
Aug 21, 2008 | Televison & Video
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung HLN617W 61" Rear Projection HDTV Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
