Question about Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up
Check engine light
My engine check light keeps coming on in my 97,bmw328i
    Scholar:
  • 88 Answers
BMW engine light
Comes on if DME engine management system self diagnostic fault detected. Will stay on until codes are called up and memory erased.
With OBD read the code as follows. Turn on ignition key, press accelerator pedal to the floor five times within 5 seconds. The check engine light will remain on for 5 sec , blik off, come on for 2,5 sec, go off for 2,5 sec and fault code will begin to flash. If more than one fault exist 2nd fault code will be separated by 2,5 sec pause. after fault codes there will be a 0.5 sec flash and light will remain off. to read codes again do procedure again.
Canceling of codes. make sure fault code is present (short blink and light goes out for long period), depress throttle pedal for at least 10 sec. read fault codes again and check for code 1444 (no faults stored.)
Check also the following, fuel pump, oxygen sensor, fuel injectors, engine coolant temp sensor, idle speed control valve, mass airflow sensor and too many other things.
Posted on Aug 19, 2009
My check engine light comes on and flashes only when i accelerate
Chances are you have problems with the ignition system.
First thing to do is get the computer scanned for trouble codes to find out why the check engine light is coming on.
Jan 31, 2013 | 1997 Nissan Sentra
I have a 97 Plymouth Voyager 3.0 engine the oil light comes on and keeps dinging for about an hour first thing in the morning and sometimes later would like to know how to fix or at the very least dis
first of all check the oil level in your engine. If is ok,then check whether the oil filter is a correct one . Change the oil filter with the correct filter and follow it for a day and if the problem gone means that the filter was not keeping the oil in a correct quantity and pressure.Also check if the oil pressure is a good one and it keeps working accurately. A simple try as a test but not for long is to disconnect the cable and follow it if there is not any warning comes on then change the oil switch.
Dec 01, 2012 | 1997 Plymouth Voyager
The engine light does not come on when I turn on the igintion. would that keep the car from starting up. it cranks but won't start up. 97 avalon
check all your fuse under bonnet or under driver or passenger compartment site.i like to know if you have immobilizer alarm in your car.
Oct 02, 2012 | Toyota Avalon Cars & Trucks
The engine cattles when am driving it but if i
The ASC light comes on when the system is operating. Ease off on the go pedal a bit on corners.
Oct 06, 2009 | 1999 BMW 328 Series
Explorer 97 check engine light
check firing order that you put the wires on right then 1 at a time pluck the wires off and replace them when you do this each one it will make the motor shake a bit more, keep checking till you pluck on the wire that shows no change in the running condition and check that wire and plug to see witch one is bad
Aug 09, 2009 | 1997 Ford Explorer AWD
My 97 honda civic dx check engine light keeps coming on
Had this issue did you replace the exhaust
Jun 19, 2009 | 1997 Honda Civic
In 97 mercury mountaineer, how to turn off "check engine" light
Go to the local parts store, have them check the codes (they will do this for free usually). It will tell you what sensor needs to be checked/replaced. Once the part is replaced, it will clear on its own. They can also reset the code, but it will come back if the trouble persists.
May 27, 2009 | 1997 Mercury Mountaineer
Check engine light
yes and itys a very common problem yu need to change the speed sensor (VSS) on the trans heres how it comes apart 4359d1c.gif
Feb 21, 2009 | 1997 Acura CL
97 Cavalier engine coolant light.
have you changed the sensor on the coolant reservoir? try that.
Feb 17, 2009 | 1997 Chevrolet Cavalier
Dashboard light
i also have a 328i it is a brake indacater tells u when u need to change your brake pades when u do this u need to find out if it is front or back because there are sensors on both after u do that u have to have it reset
Jun 18, 2008 | 1997 BMW 328
Pro-Fit Pro.Fit Bm 51 97 Bmw 528i/540i/530i 97 Up Logo
729 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
