Question about Sony Playstation 3 (PS3) Console
Hard disk gone bad
When I turn on ps3 it says correct hard disk not found. Can i buy new hard disk which I found on amozon and just replace it.
  • 99 Answers
I am not 100% sure but there is a risk associated with order most electronics over the internet. The reason for this is most products are embedded with whats known as "Regional Programming" or "Regional Coding".
Regional coding makes products only work in specific pre programmed regions (or with products from those regions ie cds from other countries dont work in your dvd plaer) the reason for this is in order to sell them internationally they have to be brought to a price relative to that market, and if you were to exchange your currency to a countries with a nlesser GNP (Gross National Product which determines international dollar value) you would be able to purchase the product from that country at a lesse price. now so the whole systme doesnt fall apart they do this.
I do not know if PS3's hardware is like this but i know international games are so just to sure i would advise against it or make sure you know where the source got the hardware.
GL
Brad
Posted on Apr 12, 2009
I dropped my ps3 and now its sayin it cant find its hard disk. how do i fix this?
If under warranty, ship to Sony. If not, check to make sure the hard drive in secure in it's hatch. There is a decent chance that,
  1. The hard drive connection is loose
  2. The hard drive connection is broken
  3. Internal Wiring is broken.
If it is 2 or 3, then you'll need to get repairs or buy a new console.
May 07, 2012 | Sony Playstation 3 (PS3) Console
When I turn on the ps3 it says... can not start, the correct disk was not found....any suggestions??
kellz0217
If you are getting a corrupted hard disk messsage on your PS3 this means that you have some bad data on the hard drive or the drive is bad. The link below will help you address this issue. If you still have trouble then you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Nov 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
WHEN I TURN MY PLAYSTATION ON IT SAY, "CANNOT START THE CORRECT HARD DISK WAS NOT FOUND"
Try and do a quick format on the hard drive, could of been that somebody switched out the hard drive with one that isn't formatted for the ps3. If it won't let you do a quick format on the hard drive then that means the hard drive that is in the system is bad and would need to be replaced. Once replacing the hard drive then go ahead and quick format it then. It should do it and then you can use the PS3 like you normally would.
May 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
It says cannot start the correct hard disk was not found. does this meen that my hard disk is toast
I have seen a few ps3's with bad hard drives which can be replaced with any SATA 2.5" hard drive. But sometimes though, all you need to do is remove the hard drive and reseat it a couple times. Sometimes the contacts can become dirty and loose connection. I would try this first before going and buying a new one. I usually get mine off of ebay, but they can be purchased at any electronics store.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Iturn on it says cannot start the correct Hard disk was not found
Open up your ps3 on the right site with a small flat screw driver.
Turn out the blue screw with a small cross screw driver, slide the hard drive to the left and pull it to warts of you, note it is a 2'5 inch sata notebook harddrive.
Hook it up to a pc or mac to run a diagnostic check on it to see if it is crashed, by the way you're able to tell by the sound it makes if it crashed.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
Playstaion 3
It sounds like your hard drive may be damaged. The Playstation uses a standard 2.5' hard drive and is user replaceable. Best Buy ,for example, sells these types of drives for $60-120 depending on the size of the drive (Number of GB) you want. Lots of guides online as to how to replace your hard drive, it's only 3 screws.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3
buy a new hard drive. it sounds like yours wore out. Make sure it is inserted all the way in too!
Mar 23, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
