Question about Amana DLE330RAW Electric Dryer
My Amana dryer will run for about 10 min. stop and will not start up untill it has cooled, I replaced the THERMAL FUSE, But it will still only run about10 min. HELP
  • 1 more comment
  • Anonymous Apr 13, 2009
    WHAT IS AN OVERLOAD?????????
  • aaron_spears Apr 15, 2009
    I DON'T KNOW???????? WHAT IS AN OVERLOAD?????????
  • aaron_spears Apr 17, 2009
    THANKS
  • 77 Answers
First unplug your dryer. You will need a 5/16 or 1/4 inch nut driver to remove the rear panel. Also, you will need to detache the vent. Once the back is off, toward the bottom you will see your element. Attached to the housing where the element is there are one or maybe even two safety switches. A.K.A. overloads. Obviously one of them or both if you have two are weak. You should be able to replace them at an appliance parts store where you purchased your thermal overload. To test them, you can place your an ohm meter across the terminals for continuity. If you catch it when it goes out and work quickly, you maybe able to isolate which one it is. Careful to unplug the dryer to avoid being shocked. Good luck.
Posted on Apr 16, 2009
    Problem Solver:
  • 13 Answers
Could be the overload near the elements
Posted on Apr 13, 2009
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Jul 23, 2010 | Amana ALG643RB Gas Dryer
Dryer runs,ignitor is "not" clicking. dryer set to automatic, with about 10 mins left on timer, dryer continued to run untill manually turned off. when re-started ignitor would not ignite
DRYER TIMER WILL NOT ADVANCE UNTIL PROPER TEMP IS REACHED.TRY IT ON TIME CYCLE.DOES IT HEAT ?IF NOT REPLACE THERMAL FUSE AND TSTAT MOUNTED ON BLOWER HOUSING .REMOVE REAR PANEL OF MACHINE TO ACCESS THIS..~COST $35+
Dec 12, 2009 | Kenmore 74612 Gas Dryer
My electric dryer is not blowing heat, just cool air. What is wrong with my dryer.
Check the following to address this issue.
1. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 23, 2009 | Amana Dryers
Amana NEW7200TW (1 year old) runs, but stopped heating.
Jul 30, 2009 | Amana NED7200TW Electric Dryer
I have a Amana DLE330RAW everything works, but it won't heat?
Jun 13, 2009 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
236 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
