Question about Vehicle Parts & Accessories
No sound coming out of siren from alarm. hooked hot and ground diretly to siren no sound. bad siren?
  • Anonymous Apr 13, 2009
    same problem,. everythign works but the siren. i had the battery unhooked for a while.
  • 22 Answers
Put a 12 vt test light on your 12vt output to see if the alarm is outputing,some alarms have to be programmed for positive output as some are negative output ie;set up to hook up to horns.Also double check your earth.
Posted on Apr 21, 2009
How do i hook a car alarm siren up
I would go with a direct to the battery red wire with a in line fuse Ground should be when you have anchored it to the frame other wires as they go to the alarm unit itself
Feb 21, 2014 | Cars & Trucks
My car alarm siren will not go off
You have a wiring issue, bad ground, incorrect relay, loose connection, faulty alarm horn... start with the alarm horn as they often fail due to debris build up and corrosion issues at the internal/external contacts... then check ground and make sure the circuit you added is on its own fuse and is not just jumped from another circuit... Post results or additional questions
Dec 30, 2013 | AviStart 5303 2-Way Security / Remote...
Siren wiring car ALARM SIREN TO TOGGLE SWITCH/WANT TO CONNECT SO I CAN TURN ON / OFF AT A FLIP OF THE SWITCH FOR CAR HORN
The siren has two wires: connect the red wire to a fused battery source. Connect the black wire to one side of a two wire toggle switch. Connect the other wire of the two wire toggle switch to a chassis ground. Now you can control the siren by applying the ground when toggling the switch.
May 24, 2013 | 850 Back Up Alarm - 107 Db Reverse Mount
Alarm is armed but when door is opened no siren
Is there power to the siren? Are the lights flashing? Can you choose to have the siren on or off? If the lights flash and there is no power to the siren it may be the controller. If you have power to the siren then make sure you have good ground at the siren even if you have to run a ground wire from it
May 18, 2012 | Cars & Trucks
Just bought a DSC SD 15w siren has six wires. Using a GE Simon XT panel for fire and burglar alarms. Siren Has 6 wires. two red two black and two yellow. Which do I hook up? Do I need some kind of...
hook up red and black wires. Red wires to HW1&2 DC Out Terminal. 1 Black wire to HW1 and 1 Black wire to HW2. Resistor 47 Ohm resistor not needed unless siren supervision is turned on as an option. If needed , should go at the speaker, across red and black wires.
May 11, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
Alarm goes off on jeep grand cherokee lorado
under the ecu on the right hand side inner wing ,near the fuse box is the siren,un plug and remove the ecu then un plug the siren remove it by any means I had to pry mine off it has its own battery pack inside,I binned mine cos it doesn't affect the running of the Jeep hope you got sorted
Mar 19, 2009 | 1999 Jeep Grand Cherokee
I have no sound coming from my AU-93 car alarm
probably the siren is damaged hook up another one or try with a tester light on the wires from the siren when the alarm is on and the lights start to flash the light on the tester light will stay on.if this happen then your siren is damaged.or email me for more help, reynosaelectronics@live.com.mx
Mar 16, 2009 | Vehicle Parts & Accessories
Volvo s80 alarm
Have the codes read out for the vehicle. It is likely that the siren for the alarm is causing the false alarm. If the siren is bad, there will be a code set in the central electrical module. (CEM)
Jun 26, 2008 | 2003 Volvo S80
Vehicle Parts & Accessories Logo
346 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
