Question about Insignia IS-LCDTV32 32 in. Television
"i have insignia 32 lcd after 15 minutes it turn off with over heated why" Problem
    Problem Solver:
  • 10 Answers
Sorry to say but I believe you have what the rest of us have had happen to our TV's. There are three capacitors on your TV's power board that have gone bad. It is an easy fix and I only paid $5.16 for the capacitors required for the fix, but if you don't have the desire to do it yourself the power board is available on bestbuy.com for about $100. You can replace it easily enough with a philips screwdriver.
Make sure you un plug it first.
This seems to be pretty common with alot of LCD TV's from what I've seen here recently.
Good luck with it,
John
Posted on Apr 13, 2009
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
TV shuts off after 10-15 minutes
Try checking to see if it has a sleep timer that is on,
if so set it to o min.
Nov 15, 2010 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Bought a 46 inch LCD Insignia and the tv shuts
I have had the same problem with the same exact TV. The TV does not have any issues while running Cable but when I am playing my 360 it sometimes shuts off every 5 minutes, if you have found a solution for this probelm please email me at foxgoalie35@yahoo.com.
Adam
Jan 02, 2010 | Insignia Televison & Video
T.V. turns off by it self right as i turn it on
Your Television is going into the protection mode. This is usually caused by some component failure. You can call Best Buy customer support at this telephone number 1-888-237-8289. They may have in house service for in warranty products. You can also call the Insignia customer support at this telephone Number 1-877-467-4289. The Insignia customer support website is www.insignia-products.com. Go to the customer support section and tell them the model number of your television and ask them for help. You should be able to get help from these sources as they will have all the correct service information for your television. I hope this information helps you with your problem.
May 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
My 32 Plasma insignia did not tur on
This unit has had a problem with component failure.The reason the unit does not turn on, is that something in the unit has failed, not allowing the television to turn on.You can reach customer support for Best Buy at this telephone number 1-888-237-8289. The Insignia customer support telephone number is 1-877-467-4289. The Insignia customer support website is www.insignia-products.com. Just go to the customer support section and tell them the model number of your television and the problem you are having. They will be able to evaluate the problem and tell you how to obtain service. I hope this information helps you with your problem.
May 14, 2009 | Insignia 37" LCD Flat-Panel HDTV
26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
Insignia FLAT screen LCD tv
It's more than likely over-heating. You can try a Battery BackUp with AVR (Automatic Voltage Regulation) built-in to see if possibly your electricity isn't coming in as cleanly as it should. If that doesn't do anything different for you then you'll have to take it to either a repair shop or back to Best Buy (if it's still under warranty).
Jan 03, 2008 | Insignia LCDTV26 26 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
289 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
