Question about Sharp R-1510 Microwave Oven
Remove Sharp R-1510 from under cabinet bracket
I simply want to take the Sharp R-1510 down so we can in install an exhaust damper and ducting. HOW do you get the little tabs to release the unit so you can pull it out?
  • sam6834 Apr 12, 2009
    After I posted the question, I figured it out. There are two release tabs which I HAD tied to move, but previously without enough force. Using a BIG screw driver as a pry bar, I pulled the tabs down about a half inch and that releases the snaps in the back of the microwave
  • Anonymous Mar 21, 2014
    Want to remove sharp r490 from under the cabinet to change the vent from outside duct to inside char coal filter...thanks
It normally sits in. So puch up to release it.
Posted on Apr 12, 2009
I have a Sharp R1870 micro/convection unit. unit kicks off after 60 seconds. have to restart then kicks off again in 60 seconds.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
I have the applicable service manuals for these models and have uploaded it to my site here and here to help you.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | Sharp Microwave Ovens
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
Unit shuts down every 59 sec. No matter how much time, with or without anything in micro and I figure to replace motor and switch. How do I get to those parts in unit? Does it have to come down?
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after 59 seconds when there's damper toruble.
See the attached sample drawing below for a typical damper assembly.
We have the applicable service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
You will have to remove the oven from the wall and remove the outer cover to access, test & replace damper parts.
Just refer to your installation instructions.
If for some reason you don't still have yours, scroll down to the bottom of this page to find yours.
Sep 29, 2011 | Dacor PCOR30 Convection/Microwave Oven
My unit stops every 58 or 59 seconds and I have to push the start button to get it to resume.
Aug 16, 2011 | Dacor PCOR30 Convection/Microwave Oven
MY SHARP R-1875 SHUTS OFF EVERY 59 SECONDS AND THE EXHAUST IS NOISY. HOW CAN I REPAIR THESE PROBLEMS.
The first is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
The noisy exhaust? That depends on what it sounds like...
It may be that the fan blade assembly is slipping on the shaft.
The solution is to take the oven out of the wall (instructions here) and remove the exhaust fan assembly from the oven.
Then you can slide the blade assembly partly off the shaft, clean the shaft with high grade alcohol (like 70% or better isopropyl) then apply a few drops of super glue to the shaft (not near the bearings) and slide the blade assembly back on.
Let it set for about half an hour before you reisntall it. Also, you may want to test it before puttting the oven back into the wall.
If you have a different problem with your fan, please note that FixYa is not notifying us Experts when Clarification Requests are answered.
So if you need more help, please post a NEW question, and please include your brand name and the full model number from the tag in or on the unit.
Oct 09, 2009 | Sharp Microwave Ovens
It cuts off after 53 seconds on sharp model r-1870
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Most computers will open this document automatically, but you may need the free Adobe Reader
http://www.adobe.com/products/acrobat/readstep2.html
http://www.microwavedisplay.com/switch_form.htm
William E. Miller
prototech@usa.net
Sep 08, 2009 | Sharp R-1870 Convection/Microwave Oven
Need assistance installing a JVM1660BB range microwave oven. How do I attach the sleave to the duct to the microwave, while mounting the Microwave on the wall. Thanks for the specs on the microwave oven....
From page 14 of the installation instructions online here:
"Extend the house duct down to connect to
the exhaust adaptor.
"Seal exhaust duct joints using duct tape."
Jun 06, 2009 | GE JVM1660 Microwave Oven
Fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
Sharp Microwave/convection oven
We had the same problem, and the service technician quoted over $300 to fix it. My wife found this thread online (click on link below) and after following the advice here ours is now fixed for a total cost of under $40, and that included a new soldering iron (see below)!
http://www.fixya.com/support/t902145-sharp_r1870
The problem is either the damper motor or the damper switch. You can order both from Tritronics and ours shipped un less than a week. It is not possible to tell which it is without disassembling the microwave, so I ordered both. In our case it was the switch (one of the electrical contacts was black like it had burned out).
Read all the advice about discharging the capacitor; I would recommend downloading and printing out the service manual (especially page 18 which is an exploded parts diagram which helps you identify what is what (click on link below)
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
Page 14 is also useful because it gives you the part numbers to order from Tritronics. The two items you may need are 1-11 Damper switch and 1-22 Damper motor.
The space is rather tight, and you need to be very careful you don't cut your hand on the sharp (no pun intended) metal. It definitely helps to remove the long mounting bolts that runs through the space. Be very careful when disconnecting the electrical connections: the little metals tabs they use on the ends of the wires break very easily - hence the soldering iron. The most difficult piece is undoing the screw on the right hand side that secures the motor; it's just cramped and you need a very small/short phillips screwdriver to get to it. I would advise removing the switch first (it's secured by a couple of little metal tabs) because then the cam which drives the damper door will be able to drop free when you remove the motor. Finally, when installing the new motor, make sure that the tab on the cam wheel is correctly inserted into the little slot on the bottom of the damper door.
As I said above, read all the advice on the other thread and the general advice on working around microwaves on the http://www.microwavedisplay.com/ web site. It's all good stuff. Good luck!
Nov 03, 2008 | Sharp R-1480 Microwave Oven
Shuts down after 59 sec
Chances are you have a bad damper switch or wiring. A sample photo is here: http://207.234.249.73/mwd/damper.jpg It might also be a problem with the humidity sensor or a problem with the control panel, such as corrupted code or bad connections.
Dec 20, 2006 | Sharp R-1850A Convection/Microwave Oven
Sharp R-1510 Microwave Oven Logo
145 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
