Question about Philips 55PP9352 55" Projection Television
Philips 55" rear proj. tv...55pp9352
Just replaced ic's and worked for a few seconds and all of a sudden screen went black and there's a chirping noise . TV will power on
  • hd85anniv Apr 09, 2009
    I changed my convergence IC's and two resitors.
    I got all colors lined up and found the blue tube to be a little weak.
    The problem that I'm having now is when I put the TV rear panel back on and turned TV back on the indicator light came on and then shut off.
    I can hear the TV turning on but no video and then turns off.
    Please somebody help ASAP???
Contact me, wheedid you get the IC?s
Posted on Jan 21, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Those ic's are to be replaced with original parts..also suggest audio ic..john
Posted on Sep 11, 2007
Screen is black while power is on with no sound but remote is working properly
If when you use the remote the volume, channel, etc options display on the screen then the TV is for the most part working fine...when that is the case the loss of video us usually outside of the tv - cables - cable box - etc
Feb 06, 2013 | Philips 55PP9352 55" Projection Television
Bowed picture on Philips 55pp9352 after replacing IC's
You must have mishandled the ICs they are static sensitive, and unless you used Sanyo ICs then you will have problems. The convergence is obviously not working so the TV will need the digital convergence board repaired or replaced, also the PIP board is suspect I have seen plenty of these tvs and believe me I earned the $ 350 we charged. These sets are very difficult to work on even for a trained tech. the best thing to do is to have a repair shop do it and you will have the assurance that its done correctly, and the work is guaranteed, That makes sense. ( I will not be able to respond to any further inquires)
Jan 04, 2010 | Philips 55PP9352 55" Projection Television
Philips 55" projection 55pp9352/17
You shorted two or more pins when you soldered the STK chips into the TV. Re-Check your soldering.
Apr 09, 2009 | Philips 55PP9352 55" Projection Television
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 55PP9352 Rear Projection, no picture or sound
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Convergence
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Mine had the same problem. It turned out it was the power board that went out. The ic's might need to be replaced again, because they could get whacked out when the power board blows out.
Sep 11, 2007 | Televison & Video
Philips 55PP9352 55" Projection Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
