Question about Acer TravelMate 290LMi PC Notebook
How do i overclock the cpu speed by the bios utility necessary to run adobe illustrator cs4
  • lexxxis
    lexxxis May 11, 2010
    you need to go into your bios and set the cpu clock speed up higher but not all bios chips have the ability to set them . WANING! your laptop could become unstable , your cpu could burn out alot faster then normal and if you set it too high depending on the chip ,board and make of your PC overheat and burn out your circuits . im not sure if that laptop is new enough to get an upgraded cpu installed in it instead but its worth a try
    Problem Solver:
  • 4 Answers
Try Everest Home Edition to get info to overclock.
Its a starting point!
www.softpedia.com/get/System/System-Info/Everest-Home-Edition.shtml
Posted on Apr 12, 2009
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
I want a serial number for my adobe cs4 illustrator .I can use my illustrator.Can you give me a serial number?
Adobe products are licensed to the original purchase of that particular product. It is a copyright and licensing violation to post or use a serial number that did not come with your edition.
Apr 10, 2010 | Adobe Illustrator CS4 Full Version for PC
Serial for illustrator cs4
Note that "software piracy" is *NOT* allowed on FIXYA.
So, telephone ADOBE, and have your credit-card ready, and pay for the software.
Jan 24, 2010 | Adobe Illustrator CS4 Full Version for PC
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Cant access advanced bios settings
to access the Bios Configuration Setup, On Any PC.
Depending On The Bios Manufacturer i.e Pheonix-AMI et,c.
You press F2 Or Delete Or Esc At The Initial System Boot-Up.
Power On. Press One of the designated Buttons immediately, after starting the computer.this should access the Computers Advanced Bios Settings.
** Please note:- Altering any settings in the bios, can cause undesireable effects to your computer**
Even failure To Start, Or Boot-Up.
From my own personnal experience, it is better to underclock a cpu rather than overclock it.
If a CPU Is designed To Run At a certain speed, running it above it,s designated speed cycle, can damage either the CPU Itself, the Memory Or Motherboard.
Probably wiser, to upgrade The CPU rather Than Overclock It.
Mike @ Compurepair.
May 11, 2008 | Intel Desktop Board D845BG Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Acer TravelMate 290LMi PC Notebook Logo
235 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
