Question about Kenwood Excelon KVT815DVD Car DVD Player
Cable Disconnected on my screen it says: cable disconnected please confirm connection Where would/could the cable be disconnected from? It must have vibrated loose or something. Thanks
  • MustangGT Mar 12, 2008
    My Kenwood KVT-815DVD says the same thing, that a cable is disconnected. I took my car to the audio shop that installed my stereo. They checked to see if any visible cables were disconnected and there wasn't any. They tried to reset the unit and that didn't work either. My warranty expired a few months ago which left the audio shop under no obligation to troubleshoot or fix the unit. They couldn't tell me at that time what the problem was or that there was even a cable disconnected..
  • 752 Answers
There is a large 20-30 pin VGA cable that goes betwen the display unit and the hideaway tuner module. It is the most likely suspect.
Posted on Sep 11, 2007
6ya staff
SOURCE:
I have a scanner Canon MP270. I have used it successfully before. Now I get a message on screen: Cannot communicate with screen. Cable my be disconnected or scanner may be turned off'. I have chec
First, please check all USB cable connections, unplug and re-plug the cable both at computer side-port and printer side-port.. Then,check if USB cable is good. If you are sure that's all alright so the logic board of the printer may be faulty. Overall this is about connection problem. Good luck.
More solution about printer at:Printer Clinic
OR
Download Service Manual
Sep 23, 2012 | Canon Pixma MP270 All-in-One InkJet...
Will not power up
Hi, Please remove the Battery from the cameraand give a look inside the battery compartment. Use a spot light & makesure that place are clean , the battery connector pin are not bend , broken orrusted. After that insert the fully charged battery and try to turn on. If itsnot turn on then its confirm the camera internal power supply unit is faulty.For few reasons this problem started.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.2. Thepower supply transformer stops working & need to replacement.3. turnon button connection may disconnected.For the confirmation all you need to visit a camera repair store. Withoutvisual survey technician can't confirm you which one of them is faulty. Thankyou
Aug 04, 2012 | Vivitar ViviCam 8025 Digital Camera
My HP 6500 printer will not switch on although power cable is connected & I have confirmed power is on. This follows a move, when printer was disconnected.
Try reconnecting a control panel. In the video below, we show how to fix the control panel, there you will see where the ribbon cord needs to be reconnected. Also, check the logic board connection if this doesn't work.
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
"Check signal cable" appears on the screen. I have disconnected
The cable that connects the MONITOR to the COMPUTER is loose or disconnected. Check the monitor cable at both ends. (not the wireless switch, router or modem).
Nov 13, 2009 | Samsung SyncMaster 205BW LCD Monitor
Harman kardon drive and play, does not load ipod screen just says please wait and has the numbers 02,1 in the bottom left corner
The error code mentioned above usually denotes a communication error a between the Drive + Play’s display and the commander knob. The first thing to check is that the commander knob is fully connected to the Drive + Play’s electronics enclosure. It might seem very tight, so giving the connector a twist while pushing it in can help ensure there is a complete connection. If you’ve confirmed the correct connection of the commander knob to the enclosure, then check to make sure that the commander knob cable isn’t pinched. Please refer to page 8 of your owner’s manual to confirm that you’ve routed your cable correctly. Then try a reset of the Drive + Play by disconnecting power to the brain, disconnecting your iPod, and disconnecting the display. Reconnect them in the following order: display, power, iPod. If you’re still having problems please consult with your dealer/installer or email us at [email protected]
Jul 22, 2008 | Car Audio & Video
"disconnected cable, please confirm connect"
do you getta dvd picture...i get sound only but no pic....????
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
Kenwood ddx8017 stereo
NEED MORE INFO DO YOU HAVE AN IPOD CABLE ATTACHED OR A SATELLITE RADIO ATTACHED HAVE SEEN THIS PROBLEM WHEN CABLES FOR THESE OTHER COMPONENTS ARE THERE BUT NOT THE DEVICE ITSELF. LET ME KNOW WHAT ALL IS ATTACHED.
Mar 07, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Kenwood kvt 715 screen saying disconnected cable found
same problems would like it if you could tell me how you resolved it, many thanks
Aug 29, 2007 | Kenwood KVT-617DVD Car DVD Player
Dissconected line
just had the same problem. it turned to be the large black cable that goes from the control box to the head unit. hope that helps.
Aug 20, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood Excelon KVT815DVD Car DVD Player Logo
415 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
