Question about Samsung DV337 Electric Dryer
Samsung DV337 Dryer; the motor runs but the tumbler not turning
Samsung DV337 Electric Dryer; the motor runs but the tumbler is not turning. It trys byt then stalls. I suspect the belt, idler or drive wheel (which ever it has) is the problem. This is a stackable unit and I have it stacked. I bought the unit the end of March 2008 and no 2-3 weeks out of warranty is is not functioning. Samsung will not provide or even sell me the parts diagram, spec so I know how I should take it apart. Was hoping for some input.
  • wanye jones May 26, 2009
    I have the same DV337AEL dryer only the tumbler stop working 4 months, after warrantly. It start then stalls I also figure it might be the belt or the rollers for the tumbler. I think I am going to order a belt and try to fix it myself.
  • 1,531 Answers
You need to remove the top of the dryer first then remove the control panel. then all the screws from the front panel then you can look inside and see what is going on
Posted on Sep 27, 2009
Motor running -no heat.Did troubleshooting from the manual-still no heat,called samsung support,went through troubleshooting with them-still no heat,run dryer on manual for 5mins.-blew cold air.Can you...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Samsung DV337 Electric Dryer
My Samsung DV337 Dryer also runs for a short amount of time and then stops. I'm getting a code that looks like an upside down F, followed by an o. I can't find this code in any service manual...
I just encountered the identical situation, after putting a multimeter to all the sensors it turned out that the thermistor was bad. I replaced the thermistor part # DC32-00007A and it eliminated the problem. You will have to remove the top and front of the unit to reach it. It's the sensor on the right in the picture.8_20_2012_10_24_55_pm.jpg
Aug 09, 2011 | Samsung DV337 Electric Dryer
DRYER WONT SPIN
it could only be either a broken belt or burnt out motor if the belt is not broken then replace the motor as there are no electronic by passes to the motor to interupt power thats if the heating coil is still heating if the whole unit is dead email me back
Dec 10, 2010 | Samsung DV337 Electric Dryer
Drum want turn, everything else shows ok
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 08, 2010 | Samsung DV337 Electric Dryer
My samsung dryer will not turn any suggestions? It is less than a year old was working fine and when I switched loads the unit lights up just will not turn
Door switch...
heatman101
Oct 24, 2010 | Samsung DV337 Electric Dryer
Hello I have a Samsung dryer model # DV337.Today I went to use it and cleaned out the lint trap. After I put the trap back I herd a Klink noise. I then turned on the dryer and it was making a noise like a...
When you pulled the lint filter something may have fallen into the blower which is just below the filter. Use a flashlight to try and see down the chute, if you cant find what is stuck there, you may need to call for service to disassemble the dryer to remove the object so it does not destroy the blower.
Apr 19, 2010 | Samsung DV337 Electric Dryer
Samsung DV337 Electric Dryer Logo
395 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
