Question about Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 Will Not Recognize Timecode
I have an Intel Core Duo iMac. I borrowed my school's Sony DSR-11 tape deck to import some of my MiniDV tapes into iMovie. The tape deck is not recognizing that anything is on my tapes - there isn't any footage or timecode showing on my computer. I'm pretty sure that the problem is with the tape deck - I've tried two Firewire cables and four different tapes, and I've tried importing it into Final Cut Pro as well as iMovie - none of this worked. My teacher told me something about the Firewire ports blowing out if you connect the DSR-11 improperly, but I followed the instructions on the box and my computer is recognizing the DSR-11 as an external device, and it's recognizing my tapes - it's just not showing anything on them.
    Genius:
  • 1,139 Answers
I think you may have misconfigured something because the problem is not in your DSR-11 try connecting it to a monitor and you will see the time stamp and picture as proof of what I am saying. The problem I think is that your Mac is not processing the time stamp correctly. Try this link first it helped me: Remember follow the instructions ezactly: http://forums.creativecow.net/readpost/35/856108
Posted on Sep 11, 2007
SOURCE:
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
Mar 02, 2010 | TDK DVM60 Mini DV Tape
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Sony dsr-45 tape
It is:
Sony cleaning cassette DVM12CLD you can buy it from ebay at 15 pounds. click on the following link:
http://cgi.ebay.co.uk/Sony-DVM12CLD-MiniDV-cleaning-cassette-in-Blister-DVM12_W0QQitemZ370257959235QQcmdZViewItem
Aug 07, 2008 | Sony DSR-45 Mini DV VCR
DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
DSR-11 pixelates on right side of Screen
most likely problem is a misadjusted exit guide post. cleaning would not solve the problem; if you have a service manual and know how to adjust the guide, you can do it yourself. otherwise, it's a job for a technician with the proper test equipment.
Dec 20, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 DV / Mini DV VCR Logo
316 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
