Question about Famous Brand F1703 Monitor
Hp flatscreen monitor won't come on when i boot my computer
I turn on my computer but the monitor says no signal and goes to sleep mode?? i have checked the wires and everything is fine then i hook another monitor to the tower and says the same thing?? is it the tower
  • t_alle74 Apr 12, 2009
    ok what is a graphics card?
  • 21 Answers
It sounds like your graphics card is conflicting weith your flatscreen , i had a sony desktop do the same thing only on a TFT or LCD monitor , you may want to get a better graphics card , my bet is its probly an intergrated one .
Posted on Apr 12, 2009
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text ever...so.
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
modes in the CONTROL PANEL + POWER SETTINGS>
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
http://pcdied.com/black-screen.html
Jul 20, 2017 | HP w2207 Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
HP monitor going into sleep mode right after turning it on
If it goes in to sleep mode, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | HP w1907 LCD Monitor
Monitor goes to sleep when computor is turned on no input signal
If the monitor is going into sleep mode the normal power led will change to another color. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays on, you have a backlight malfunction. It can be bad capacitors causing an inverter power fault or it may have worn out backlights causing a shutdown condition.
Monitor Mike
Aug 17, 2010 | HP w1907 LCD Monitor
My monitor keeps saying monitor going to sleep waht do u o
It shows that the monitor is going to the power saver mode.It is not a problem of the monitor.This happens when there are no signals received on the monitor.It turns back to the normal mode when a signal is received on it.
Dec 21, 2009 | HP w1907 LCD Monitor
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Why does my monitor say "no signal" when you try to us my computer after it has been on sleep mode?
The computer turns off the signal to the monitor after it goes into sleep mode. You can adjust the power settings in the computer to not turn off the monitor.
Sep 21, 2009 | Acer X193W LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Famous Brand F1703 Monitor Logo
390 people viewed this question
Top Famous Brand Computers & Internet Experts
David Payne
David Payne
Are you a Famous Brand Computer and Internet Expert? Answer questions, earn points and help others
