Question about HP iPAQ hw6515 Pocket PC
Can't view any messages in Messaging
From the Today page and on the messaging folder structure there are numbers next to the foldername indicating new messages e.g. Text Messages > Inbox(15), also for the drafts folder and in the emails, however when the folder is opened no messages are displayed - at all, not new or read messages - not one message in any folder can be displayed.
  • 490 Answers
Try by doing soft reset path put ur stylus in hole which is located on left bottoom corner of ur phone but before that take out ur memory card or try with hard reset but before doning it take back up of ur phone with cable on pc or memory card . path click on n/w bars u will get format option
Posted on Oct 20, 2007
SOURCE:
How can i know number of sent messages in nokia c3.... message counter
click on the messaging icon in main menu and in there click on "options", in there click on "inbox view". this will change your conversation view to inbox and sent items, click on sent items and at the top of the screen it will show you the amount of messages in the folder (which will be the amount of messages you have sent) hope this helps
Dec 21, 2011 | Nokia C3 Cell Phone
Tip
How to delete multiple text messages on a Samsung Intensity
On many mobile phones, you only have two options for deleting text messages: deleting one message at a time, or deleting a whole folder at a time. However, the Samsung Intensity (among other phones) gives you the option to delete multiple text messages at once without deleting an entire folder. You just have to know how to do it.
Go into the Messaging menu, either by pressing the upper left option button or by going into the main menu and selecting Messaging (option #2). Select your inbox, then press the upper right option button (Options). Select #9, Msgs View by Contact. The text messages in your inbox are now grouped according to who sent them.
From this view, you can delete multiple text messages at once. Press the upper right option button again and select choice #2, Erase Multiple. Now as your messages are displayed, there is an empty box next to each one. Scroll down through the list and select the messages you want to delete by pressing the center of the directional pad. A check will appear next to that message. To uncheck a message, repeat the same process.
The only messages you won't be able to delete are messages that you've previously marked as locked. If you want to delete a locked message, you'll have to unlock it first, then delete it.
Once you've put a check next to all of the messages that you want to delete, click the upper left option button (Done) and you'll see a confirmation message. Choose whether you want to delete all of the checked messages or only the unread ones, and then click the directional button (OK). The messages you selected will be deleted.
To resume having your messages displayed in chronological order, click the upper right option button and choose option #4, Msgs View by Time.
on Jan 12, 2011 | Samsung SCH-U450 Cell Phone
I can't read offline and any messages on screen, and can't send messages too.
Dear Friend,
Please download latest version of Yahoo Messenger....... and use following instructions -
Click the Messenger menu in Messenger.
  1. Select Preferences.
  2. Click the Archive category.
  3. Check the Enable Archiving option. Enable each item that you want to archive. If you'd like to automatically delete archives after a certain number of days, place a check in the box next to Automatically Delete Files Older Than and enter a number.
  4. Click OK at the bottom of the window.
Please Note: Uncheck the Enable Archiving option if you'd like to disable Archiving.
To view your archive:
  1. Click the Contacts menu in Messenger.
  2. Select Message Archive.
  3. A new window called Message Archive for {your ID} should appear.
  4. Select the archive folder you want to review.
To delete your archive:
  4. Select the Messages folder and then click the X button if you want to delete your complete Message Archive or select the desired folder and then click X to selectively delete.
A few things to remember:
  • Under the Message menu, you can reply, save, and print messages, as well as view your archiving preferences.
  • Under the Edit menu, you can copy messages to your clipboard or delete messages.
  • Under the View menu, you can enable timestamps.
Please Note: Archives (.dat files located on your system) are encrypted and can only be viewed by the Yahoo! ID that created them. These archives are stored locally on your system, so the conversations held on that specific computer are only accessible from that computer. Once archives are deleted, they're gone, and cannot be retrieved.
Please vote after working...
Best regards,
Pramod Bhikam Singh
Apr 22, 2011 | Yahoo Messenger
My nokia n86 won't send text messages. i got it new today
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sep 25, 2010 | Nokia N86 Smartphone
How do I set up the voicemail feature?
Messaging - Advisory
To turn Messaging - Advisory on:
1. Press SUPERKEY.
2. Press the No softkey until "Advisory Msgs?" appears.
3. Press the Yes softkey.
4. Press the Next softkey until the desired message appears.
5. Press the TurnOn softkey.
To turn Messaging - Advisory off:
1. Press SUPERKEY.
4. Press the TurnOff softkey.
Messaging - Callback
To leave a Callback Message on a telephone when you hear busy or
ringback tone:
! Press MESSAGE.
To respond to a Message Waiting condition on your telephone:
1. Lift the handset.
2. Press MESSAGE.
A call is placed to the message sender (voice mail system or extension user)
that left the oldest message.
To view information about the messages before responding:
1. Press MESSAGE.
2. Do one of the following.
" To call the message sender, press the Call softkey (if available).
" To delete the message, press the Erase Msg softkey.
" To view the next message, press MESSAGE.
Jun 10, 2010 | Mitel Superset 4025 Corded Phone...
Automatic page updates causing problems with your
It's means that the new page resolution is too big for your screen. Try the yahoo classic to read your emails.
Mar 03, 2010 | Yahoo Messenger
Inbox setup (Motorola KRZR)
sorry but with v3 that is not possible
Dec 28, 2008 | Motorola Mobility RAZR V3
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
San disk error
Replace the card
Oct 22, 2017 | Cameras
HP iPAQ hw6515 Pocket PC Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
