Question about Canon Office Equipment & Supplies
D880 Imageclass - paper jam - accordioned in machine past access point (access point is remove printer cartridge) - have tried to take machine apart to area where paper jam occurred - so far cannot get it apart that much.
  • 66 Answers
The jam is in the fuser assembly. you will have to have a technician fix this. the fuser will probably need to be replaced.
Posted on Apr 13, 2009
I agree with eric400. You generally will have to replace the fuser assembly. I've gotten a machine running temporarily, by getting the fuser out, taking it apart, and clearing the jam until I got a new fuser. New fuser assemblies will run ya $200 - $300. My suggestion, invest the money in a new copier, and use the D880 as a boat anchor.
I know that ain't whatchya want to hear, but they make these units throwaways, by making them to expensive to fix!
essgee
Posted on May 14, 2009
Can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Mar 02, 2012 | Canon imageCLASS D880 All-In-One Laser...
Paper jam internal, can't access. accordian at exit tray
more the likely it is in the fuser unit of the copier .
May 04, 2010 | Canon ImageClass D880 Copier
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam that I cant get at
the paper must be jammed in the fixing assembly.
you are gonna have to remove some screws to remove the plastic covers. once you took them off proceed to unscrew what ever needed in order to free the fixing assembly, which is the one located in the upper back part of your copier. once you released the fixing assembly release the springs and remove the metal stoppers. now you should be able to remove the paper jam. good luck!
Jan 27, 2009 | Canon ImageClass D880 Copier
Can't replace cartridge in Canon ImageClass D880
Something is blocking the access, or the clips may be bent or broken
Dec 24, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Jul 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
159 people viewed this question
old marine
old marine
