Don't know how to print photos from my iMac Apple computer
I can't find ANY instructions for Apple printing photos. When I try to print I can print words on plain paper but no photos on photo paper, the c4440 sounds like it is printing but the paper comes out blank. Can I download printing instructions?
ctf1800
  • 4402 Answers
SOURCE: printer will not print on photo paper
Go into you printer on the control panel select properties> advance button and chose 4X6 and make it letter
Posted on Dec 04, 2007
Patrillica
  • 141 Answers
SOURCE: Printing Problem
You may have a problem with your magenta color cartridge ????
Posted on Mar 25, 2008
venusPCgurl
  • 26 Answers
SOURCE: My HP Deskjet F2100 All-in-one
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Posted on Aug 24, 2008
  • 162 Answers
SOURCE: won't print on the photo paper
You didn't mention what paper you're using so for simplicity I'll assume it's an HP paper. When you installed your printer, it installed profiles for the HP papers and associated them with the printer. If you go to the Printers and Faxes folder, right-click on your printer and choose Properties, you'll get a dialog box for your printer. At the top it'll say something like HP Photosmart D7200 series Properties. Click on the Color Management tab, it'll show you a list of profiles associated with your printer. Your paper profiles will be named something like HP PS D6100_7100_7300-Advanced Photo. Don't worry about the names or selecting them, as long as they're listed you're OK. If they're not listed you'll need to re-install your printer software. Close the Properties box and the Printer and Faxes window.
Now go to LR, select your photo and go to the Print module. Scroll down the right panel until you get to the Print Job Header at the bottom. If you don't see any choices, click the triangle and open it up. Uncheck Draft Mode Printing and Print Resolution. Under Color management, click the triangles to the right of Profile:. This will open up a list of all paper profiles visible under LR. If you don't see your HP paper profile, click Other and it will list all the paper profiles on your system. Find your HP paper profiles and click the box next to each, this will make them visible in the LR drop-down. Hit Close and select the profile for the paper you're using.
Now click the Page Setup button, that will bring you to a dialog box where you can select your printer, page size and layout. Make these choices and then click on the Properties tab for your printer.
Now things get a little sticky... The HP driver has an infuriating habit of changing settings you've already made when you change something else. You'll come up in the Printing Shortcuts tab, ignore this and click on the Features tab. It's been quite a while since I used this printer so I may be wrong about the right order to do things, but here's what I remember: First, select your paper size. Click the Borderless box if that's how you want to print or uncheck it if not. Your Paper Source should be Main Tray for 5x7 or larger, Automatically Select for 4x6's that go in the top holder. Select Best or Maximum dpi for Print quality, then choose Paper Type, set it for Other Photo Papers since you'll be selecting the paper profile from LR. Hit the radio button for Print At Actual Size, go to the bottom and turn Photofix off.
Now go back to the top and click on the Color tab, select Print In Color and under Color Management, select Application Managed Colors.
Now go back to the Features tab and make sure nothing has changed. If it has, reset it, check the Color settings again, check the Features settings one last time. Then hit OK and you're back in LR.
Before you print, go over to the left panel and hit the Add button at the bottom. This will save all your settings and lots of time and aggravation by not having to go through the whole process again next time you want to print something. Name your profile with at least the size, layout and paper type you've set up and it will show up under User Templates. Then the next time you want to print on the same paper at this size, you just have to select this template.
Now hold down the Alt key, hit Print,
Posted on Nov 24, 2008
SOURCE: Printer will not print on 12x12 paper. Just ejects blank page.
My printer can not print when i give a print command.
Thanks and hope to hear from you.
Regrads
John.
Posted on Nov 27, 2008
How do you replace a hard drive in white imac 2006?
First Gen Intel iMac Hard Drive Replacement Part 1
I would take a look at this video to see if this is something you want to take on. These are not the easiest computers to disassemble but if your good at following directions and if you have the right tools, you should be able to do this.
May 13, 2014 | Apple iMac Computers & Internet
Print from iPhoto
Select your photos and select print. You can also order prints online through iphoto, selecting your photos first and then going through the menu bar to order prints.
Nov 11, 2012 | Apple 21.5" iMac Desktop
My printer X5250 is working perfect as
I just wonder if you are some problem with the fonts being transferred to the printer.You could try changing the font you are using to one of the system fonts i.e. Times or Helvetica. Also go to the applications folder open up the app called font book and see if there is any conflict of the fonts you are trying to print. see http://www.lexmark.com/publications/pdfs/2007/5200/macxug/en/PrintsDifferentFonts.html
Jan 17, 2012 | Apple iMac G5 Desktop
Epson r320 printer w/ no advance settings when linked w/ new IMAC
I had the same problem when installing my Epson R300 onto my new iMac (Snow Leopard). The first install used the newest online driver from Epson. The printer symptoms were exactly like yours. Then I installed the Apple driver updates. It was seamless and now the printer settings can be accessed. Perhaps if you uninstalled (read about that on the Epson site first) and then downloaded the new factory driver, followed by the Apple update which will further update files, you might have some luck. Just a guess on my part. Best wishes.
Mar 04, 2010 | Epson Stylus Photo R300 InkJet Printer
27'' Imac won't print
try to print and in the print window click the blue button on the left of the top box with hopefully two arrows this should give you the option to choose a printer, follow the prompts when the brother is connected and on and you should get there.
Nov 19, 2009 | Apple Computers & Internet
Priner OK with PC but will not print from Photoshop used on iMac
that is a common problem with the new leopard software by now I think they have fix that so try to download the latest drivers if not check your printer settings
Sep 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
Can't scan from HP psc 2400 to iMac computer
You need to set up the software on the iMac. The reason it gives you that error message is because it can't communicate with the computer and imaging software as the computer doesn't see the scanner and can't communicate with the printer's control interface. The iMac may see the printer and be able to print without any additional software because the driver package for the printer portion may already be installed with the OS X HP printer driver support. You didn't mention whether or not you could print from OS X. I am assuming you can. Faxing and copying from the unit doesn't use the computer at all and doesn't need to communicate with it. Scanning and printing do. If you can't print either then none of the driver or support software is installed and you have to set it up. You can get the instructions for setting the printer up in OS X 10.5 from HP. Just click here and it will take you to the page with the instructions.
Best wishes and cheers
Jan 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Switching between color and black and white
Go here. In the search box in the center of the screen, type "print with black ink only" and click Search. Choose the appropriate link, and you will get instructions for printing from either Windows or Mac.
Jul 03, 2008 | Canon MX300 Office All-In-One Printer
344 people viewed this question
k24674
jasbo
jasbo
