Question about Jack Lalanne Power Juicer 250 Watts
Have no manual. Need to know how to clean it,
Have no manual. Need to know how to clean it, specifically detaching bladed area from base.
Since it was saturated with blueberries, pears and yogurt, the house began to smell, so I put it outside in a wheel barrel. In the morning it was covered in ants and the juicer now resides at the West Sonoma County Disposal.. Problem solved.....
Posted on Apr 13, 2009
Manual for Emson Juice Extractor, Model GH-2011
I bought one without a manual today for 2 dollars at a yard sale , blades lock in about a half inch - turn counter clockwise to remove, may need to press down or press button in back. base below comes off too for cleaning - turn clockwise. They may come off hard the first time. the button in the back may help releasing both. Make sure to unplug first. I don't have a manual either, just some mechanical sense.
Oct 07, 2014 | Juicers
How do you open the acme juicerator to clean out the extract
I have a 1962 manual which might be too old but here's what it says: When juicing is completed, simply remove the spring-clamp top, unscrew the wing nut or spring clutch that holds down the cutter blade, and all parts to be cleaned may be lifted from the base. Bowl and top, being non-porous, similar to glass, require only rinsing. Blade should be washed under running water, using a stiff brush. Since the basket is made of stainless steel, it, too, cleans easily. After taking out the the pulp, let cold water run on the outside of the basket while you brush the perforated section. Any remaining particles of pulp will be loosened and can be removed with a damp sponge or by rinsing. Dry and reassemble for next use. Turn machine on and let run a few seconds.
Hope this is of some help.
Sep 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
How does it come apart for cleaning
The hot water did work for mine. Here is the solution I discovered:
After removing the food plunger and juicer cover: (1) Unscrew the 3 screws that hold the cutting blade plate in the center of the basket and lift off the cutting blade plate; (2) Unscrew the base counterclockwise (it will unscrew from the threaded center piece) and lift it up; (3) Lift off the basket and juice bowl. Now you can clean the basket and juice bowl.
Sep 20, 2009 | Juicers
Lost manual need cleaning instructions what tools are needed
Jack Lalanne Juicer Operating Manual 4 pages
http://www.myeasypics.com/is.php?i=488927&img=jack_lalanne_operating_manual__0001.jpg
http://www.myeasypics.com/is.php?i=488928&img=jack_lalanne_operating_manual__0002.jpg
http://www.myeasypics.com/is.php?i=488929&img=jack_lalanne_operating_manual__0003.jpg
http://www.myeasypics.com/is.php?i=488930&img=jack_lalanne_operating_manual__0004.jpg
For the blade tool: Just find a big wire around 1/8 diameter. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves.
Jun 09, 2009 | Jack Lalanne Power Juicer 250 Watts
I need to know how to take this puppy apart for cleaning...
If you don't have the orange blade tool, just find a big wire around 1/8 diameter. Bend it and insert both ends on the blade holes. Cover the sharp blade with cloth or use leather gloves.Turn the blade.
Apr 11, 2009 | Juicers
No manual, how disassemble for cleaning;miss platform/extra blade
I just posted this info on an earlier question.
Here's the link to the owner's manual (PDF) you can save or print.
http://www.powerjuicer.com/pdf/express.pdf
FROM THE TABLE OF CONTENTS
Important Safety Information
Helpful Hints
Parts List
Assembly
Disassembly
Cleaning Your Juicer
Troubleshooting
Jan 20, 2009 | Jack Lalanne Power Juicer 250 Watts
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
How to clean juicer
i had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
Jun 10, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
208 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
