Question about Curtis DVD5091 Theater System
How Curtis 5091 DVD home theatre speakers can hang on the wall
For these speakers, there are no holes given back side...having flat surface. Can any one suggest if you have used same type of speakers on the wall with the help of any adhesive clips
    Scholar:
  • 152 Answers
I dont think I would use adhesive because of the vibration. Have you considered using a picture hanger? the short brass ones with the little divits on the bottom? I know that would mean permenantly attaching them, but they would be invisible from the front.
Posted on Apr 14, 2009
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
I have a Dynex Flat Pannel TV with a DVD player in the TV. I have it hooked up to my HD line coming into the house. My question is: Is there a way to hook speparate speakers from the TV and by-pas the...
Yes you can provided your tv-has a headphone jack. Just plug in any regular computer speakers or the like into the headphones jack and the audio output would be switched to external speakers automatically. On the contrary if your tv does not have a headphone jack then you will need to obtain a home-theatre system and connect the stereo audio out ports to the audio in of the home theatre system. They have become very affordable these days and I have seen a Philips home theatre system(2.1) starting at around 120$.
Apr 04, 2011 | Dynex Televison & Video
Show me how to set up my curtis 5091 to my dvd and tv
The speakers should not be a problem. All the sockets are labeled left / center / right / left surround / right surround and subwoofer.
Connect the yellow composite video out to the TV's yellow composite video in . Along with video out of the Curtis you can connect two red and white audio out to the TV's audio in socket.
Mar 15, 2011 | Curtis DVD5091 Theater System
How to install a home theater
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
•2
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
•3
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
•4
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
•5
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
•6
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
•7
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
•8
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
•9
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
Mar 13, 2011 | Philips 55PFL7505DF7 55 in LCD TV
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
No way to get sound on tv only on speakers how do i hook this up
i got a curtis dv 5091 can you help me cannot hear nothing
Jul 26, 2010 | Curtis DVD2054 Theater System
Curtis DVD 5091 Home Theatre System
I believe I have the solution....but it depends on your dvd player's zuxilarily capabilities. Do you have a second set of OUTPUT plugs that are colored Red and White on the back of the TV? Do you have a separate Red and White INPUT plugs on the back of the dvd? The TV must use the speakers in the DVD system by pushing the sound OUT. You cannot accomplish this if the dvd is only pluged into the INPUT of the tv.
\Another option is o make sure your DVD player has a "auxilary" or separate input channel on the console or remote.
I have a DVD home theatre system as well, not the same brand, but that shouldn't make a difference . Its a matter of how the sound is received.
Hope that helped.
Apr 29, 2009 | Curtis DVD5091 Theater System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Curtis 5.1 speaker system
i was given a curtis5.1chspeaker system and have a pioneer dvd player and a 32"westinghouse flat screen all with no manuals. how do i hook the system up? it's driveing me nuts
Feb 12, 2008 | Audio Players & Recorders
Curtis DVD5091 Theater System Logo
338 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
