Mitsubishi cs35803 tv
Fly'back transformer noise after ~20 minute warmup.
  • 34 Answers
SUPER GLUE OR EPOXY IRON FERRITE CORE ON FLYBACK LET DRY 24HR
Posted on Apr 12, 2009
Mitsubishi Colour TV Receiver Model CT-14AM1S(B) Fly Back Transformer
Download the service manula to your Mitsubishi. Click here to download it. It will have this detail, in its parts list.
May 17, 2012 | Televison & Video
Tv screen is completely dark and barely see-able tried unplugging and plugging back in. please tell what this problem could be
solution
step 1: at first check your TV contrast control switch
step 2: Test your fly back transformer
step 3 : A.C. transformer out put voltage test
Jul 27, 2011 | Mitsubishi WD-60737 60 in. HDTV
My Television problem is that when you press on the power button you hear sound but no picture on the screen but the noise you hear is not the sound like people talking . I when to a technician an he...
The problem arises from the fly back transformer not converting enough current to be used by your TV. This fault might have cause some other components to malfunction. I would advice you replace the fly back transformer immediately, as a first approach. Thanks
Apr 21, 2011 | Sanyo DS31590 31" TV
Plug tv in but all it does is make a thump thump noise. power will not come on.
The problem is most likely caused by a defective fly-back transformer, it generates the high voltage that energizes the picture tube and along with the video circuits produces a picture, to repair the set would not be cost effective when you consider the parts and labor involved, better to replace.
Feb 09, 2011 | Apex Digital GT2015 20" TV
I have a 65" mitsubishi rear projection tv, it has
The ONLY way to "Fix" this is to power the set via a 1:1 ISOLATION TRANSFORMER. You have what is called a "Hot Chassis" set, where there is mains on the actual chassis.. this is usually NOT a problem, however obviously in your case it is.. This is unusual, so it may pay to get an electrician to check things out.
in any event using the isolation transformer will stop any current flowing back.
Feb 01, 2011 | Mitsubishi WS-65807 65" Rear Projection...
TRANSFORMER LOCATION T902 HAS FAILED, WHAT IS THE REPLACEMENT PART NUMBER?
Are you sure it's not T402? That would be the Fly-Back Transformer, PN: 265399.
It would look something like this:
Jun 29, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Blurry picture
Ok, if you require Fly back Transformer for your Toshiba TV, its available in Part Store.
Static noise and focus issues are related to fly back.
Oct 02, 2008 | Toshiba 32HF73 32" TV
Krazy colours
Hi if picture is of it could be convergnce ic and that would require a tv tech cost is 250.00.
But the arching noise is usually your high voltage arching from fly back or spiltter you could take off back be careful it is very high voltage only do if you now this stuff, and you will see it arching when it is on and where ever the arc is coming from is the problem the fly back is a large transformer and is black with red high voltage lead coming out of it the leads could be bad to.
the splitter is where all the leads go into from tubes. i hope this helps cost to fix for tv shop is 350.00. thanks doctor video
May 04, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
