Leaking I have an outdoor spigot that is leaking from the handle and were the water comes out. I have replaced the rubber washer , but still leaks water. What should I do next?
  • 15,935 Answers
The entire valve must be replaced - and not separately servicable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Bowl filling after use
Try turning off the water spigot on the wall, one at a time.
If the water stops filling then one of the inlet valves in the washer is sticking open.
If you turn off the water spigots on the wall and disconnect the hose(s) from the washer, possibly it can be cleaned or unstuck. it may need to be replaced.
If you disconnect a hose be sure the water spigot on the wall is off. If you can't turn the handle on the wall, don't force it. You can turn off your main house water valve (which turns off water to whole house). Also, put a towel under the hose connector before disconnecting so you don't have water dripping everywhere.
If anything is hard to turn, don't force it. You may need to call an experienced plumber to do the work otherwise you may damage parts and create a big water leak/mess. Here is an example of external (wall mounted supply line valves
Here is an example of an internal water inlet valve:
asher Water Inlet Valve Part Number 5220fr2006h SAME DAY SHIP GUARANTEE...
Mar 25, 2016 | Washing Machines
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
Mar 02, 2014 | Delta Faucet Plumbing
Center Leak Spigot Spicket
Once upon a time, you could cure this problem by turning off the water, applying a wrench across the flats shown in your video right below where you removed the handle, and unscrewing the stem. Then you could check the condition of the washer before winding string-like packing around the coarse theads of the stem and reinstalling. The water supply could be turned on again and the problem would be solved. That was then... Today it is doubtful that your local hardware emporium even knows what stem packing is, let alone stocks it. Anyway, it's worth a try
May 17, 2013 | Plumbing
Outdoor Spigot Leak
You may exchange the washer in the spigot or just change the spigot which is simple.
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
Changing a washer on an outdoor tap
Turn water off. Remove top of valve one with handle in it. Replace washer.
Mar 09, 2012 | Garden
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
