Question about Mintek MDP-1770 Portable DVD Player
Will not play disk comes up no disk
Everything works on the dvd ,except it won;t p-lay disk comes up with no disk
    President:
  • 814 Answers
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Posted on May 29, 2009
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
Finalizing the DVD
Well this sounds like the disk was removed too fast from the camera before it had ended writing, you need to stop filming, wait at least 1 minute then remove disk because it ends the disk write not you yourself.
May 23, 2010 | Canon DC210 DVD Camcorder
Toshiba SD-K625 5 disk player won't play DVD but will play CD
Could be that the laser mechanism has lost its ability to focus properly on the dvd disks. U might want to try a firmware upgrade just in case the player has corrupted software. If not effective, then it is time to go shopping since a repair is not cost effective.
Mar 31, 2017 | Toshiba SD-K625 Multi-disc DVD Player
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
READING NO DISK
the disk will not spin at all. the screen says no disk. this device is knew . what will cause this
Oct 08, 2008 | Philips PET702 Portable DVD Player
Rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
Dvd writer problem
If everything works fine except that disk then its the disk its self.
either there is a scratch on the disk or it was a bad burn from the manufacturer.
Nov 03, 2007 | Computers & Internet
Mintek MDP-1770 Portable DVD Player Logo
181 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
