SOURCE: The motion control levers became tight to move and
You may have some bent or out of adjustment linkages, causing the brakes to stay on.
Or the friction nut (one on each transmission) is too tight. These are located just in front of the axel, they go through a slot, the washer behind the nut should turn freely
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Testimonial: "Thank You very much for your support on this matter. "
SOURCE: My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
SOURCE: I have a Toro Time
What you have is an engine that has a carburetor problem that has probably diluted the oil to the point that the crankcase is over-filled. Drain the oil and filter, then replace oil. Sometime the carburetors on these unit will become porous or cracked inside and will allow gas to enter the fuel bowl while the engine is not running. Some signs of this is that the engine will drag or static lock when you try to crank it over.
I've gone to the point to even put an inline fuel shut-off valve in the fuel line so that the fuel can be shut off when the engine is not running to temporarily deal with this problem until a new carburetor can be located and installed.
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
