Question about Kenmore 46462 Front Load Washer
Starts okay but then stops and flashes F-11.
My kenmore front loader starts okay but stops and flashes F-11.
  • nanob1980 Apr 12, 2009
    Can anyone tell me how to fix an F- 11?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
  • Daddie0 Apr 27, 2011
    blueextc-
    Are there any other troubleshooting steps? The ones you listed are very helpful, but I'm not so confident in my multimeter skills. Specifically, when you say "Connector 3 is the power supply - 120VAC should be read across pins 1 & 2" do you mean while the machine is plugged in and under power? Is there any chance that it's a bad panel sensor switch? I'm only asking because I have the same problem but it started after I pulled the panels. One last question, are there any links to diagrams and/or photos of the pin configuration you refer to?
    Any additional thoughts or insight you can provide are appreciated! Thanks for sharing the info above either way...
Why does my kenmore front loader washer get the f 11 code and stop what can I do?
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
May 05, 2008 | Kenmore 82836 Gas Dryer
When washing, it stops and says F11. What does that mean?
F-11=Serial Communication Error
Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
PotentialCauses
. CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
Unit (CCU)
. Checkt he Drives ysteml or anyw orno r failedc omponents
. ReplaceM CU
. ReplaceC CU
. Replace Motor
. ReplaceW ireH arnes
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
My front loader stops at every cycle. Is there a simple solution to this?
Jan 22, 2008 | Kenmore 44832 Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Kenmore 46462 Front Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
