Question about Cyclone CA2098 Car Amp
My left channel input for the rca on my amp is not picking up any signal or powering the subwoofer, both of my rca cables are fine and the connections are correct just the amp will not play the left channel?? HOw do i fix?
  • 68 Answers
Is the gain turned up on the amp, is the sub set to low frequency, maybe your head deck settings have bass/subwoofer off or bal set to front of the car.
Posted on Aug 05, 2009
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
Hello ! I'm not sure how to connect my kef psw 2500 sub to my yamaha amp. I've got a subwoofer out on my amp but there's 4 inputs on the sub and I don't no which one to use ! Please help as getting...
Just for clarity, I need to explain what the four inputs are on the KEF subwoofer. There is a left and right RCA input which is the input signal to the subwoofer and there is a left and right RCA output which is the High Pass output from the subwoofer.
On the back of the Yamaha receiver, you said you have a subwoofer output. This output is most likely the mono subwoofer part of the home theater system and can be used if you like. The left right signal input into the KEF is summed into mono so if you only connect one channel you will basically reduce the signal level by 1/2 (-3dB) but it will work fine.
Alternatively, if your Yamaha receiver has monitor out and monitor in, you can run the monitor output signals to the subwoofer and you can then run the high pass outputs from the subwoofer back to the monitor in. This will give you the subwoofer and provide a smoother signal matching with your audio system.
It is not always easy to connect the subwoofer up to an integrated receiver/home cinema system using the high pass channels of the subwoofer as you don't always have access to the analog output and input of the front channels. In this case, just use the Subwoofer output or just the monitor out only.
I hope this solution is helpful.
Dec 03, 2010 | KEF Audio PSW 2500 Subwoofer
Which is the best way to hook up a Subwoofer?
Last two questions first - YES, use an RCA splitter to share sub line level out between two subs and use one at the subwoofer end to share that line with both inputs on the sub.
Either attachment scheme you describe would work.
Not being a big fan of conversion/deconversion for no real purpose, I would avoid stepping the high-level input down to line level for use by the sub's internal amp, run RCA to the sub(s) and keep them physically and electrically independent of anything else unless cable routing is facilitated somehow by daisy-chaining other speakers from the sub(s).
Jan 17, 2010 | KLH PSW8100-8 Subwoofer
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Subs not programmed into dash...?
It sounds like the input gain on the amplifier needs to be adjusted.
OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
I got 4 ''15 inch kickers 2 5500watt power acoustik mono amps my problem is 2 kickers on the right side hittin hard but the 2 on the left not.i thought the amp on the left was bad so i took the rca of the...
Hello herb31,
It sounds like there is a difference in the signal levels on the inputs to the amps. You did not specify what the RCA's are connected to on the head unit side. If they are connected to a stereo pair of preamp outputs, you may be able to solve the problem by using only the channel with the higher signal and use an RCA "Y" adapter to split it to both amps. If they are connected to a dedicated subwoofer output on the head unit, make sure that the head unit is set for "subwoofer". Some less expensive head units, I know JVC in particular, has only 1 set of line outputs and requires you to go into their "PSM" (Preferred Setting Mode) to set the line output mode and if you select "subwoofer", then allows you to select the low pass frequency.
If you are converting speaker-level outputs through a "line out converter", check both the input and output levels.
Also, if you are splitting an output from the head unit, you still need to connect 2 RCA's to the amp inputs. The signal will be properly split if you use a 1-female to 2-male "Y" adapter. To feed the same signal to both amps, you would need 3 "Y" adapters. Feed the output signal to the female end of the first "Y", and plug the male ends into the other 2 "Y" adapters. Then, the 4 plugs you have left on the ends go into your amp inputs.
Hope this helps.
Apr 24, 2009 | Power Acoustik CLASS D SL-5500D Car Audio...
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Feb 11, 2009 | Polk Audio PSW10 Subwoofer
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Cyclone CA2098 Car Amp Logo
123 people viewed this question
Top Cyclone Car Audio & Video Experts
xxxxxx xxx
Are you a Cyclone Car Audio and Video Expert? Answer questions, earn points and help others
