Question about Denon DN-HS5500 Turntable
The 5500 doesn't recognize the files on my ipod, which are mainly cd's impoted to itunes, so i converted all the files to MP3 but it still isn't recognizing the files. what do i do?
Actually there are 2 possible solutions to your problem. When you plug in your Ipod or USB drive into the Denon HS5500 the machine will put a file on the drive called "Denon_DJ". This file needs to be deleted each time you add new mp3's to your ipod or usb device or your new files wont be shown.
The second has to do with what type of mp3 you are using and what sample rate it was created with.
For instance I record music with my computer and keyboards. I like to record in 96KHZ because it sounds so much nicer than 44.1k. Well the Denon wont read anything created with a sample rate higher than 44.1K . I downloaded a song from a DJ friend that was recorded in 48KHZ and made into a 196k MP3 file. The Denon wouldn't play it because it is not 44.1. Check your manual or check online.. the Denon reads 44.1k 320kbs and lower files only.. (Bad Denon)
You may also want to avoid what are called Variable Bit Rate files. Most files you download online are ripped at a variable bit rate. The Denon will play variable bit rate Mp3's .. But you will not be able to save cue points or save memos to the system. I found this out the hard way. So. I took all the files I had created that were VBR and put them into Audacity with the Lame MP3 plugin and set the bitrate to 320kbs and now I can save memos.. But everytime I put the USB flash drive into my pc and put new songs on I have to delete the Denon_DJ folder.. Its sad too because thats where the HS5500 stores it's playlist files... :( Bad Denon. They should have asked me to write the software.. xD
I hope that helped you..
Posted on May 28, 2009
  • 30 Answers
Fat32, meaning it can only read 32G hdd or less formatted with fat32
Posted on Nov 14, 2012
I dont know what to do to my Ipod on itunes all it keeps saying is connect to itunes what do i do
Is the Ipod on when you connect it? If so, reset it and connect it again. If that doesn't work, check that the cord you are using isn't broken or your Ipod's jack isn't messed up. If it still doesn't work try a different usb slot on your computer.
Jun 07, 2012 | Apple iPod touch
Tip
How to convert m4p music to mp3
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Convert m4p to mp3,itunes to windows media, convert itunes music
The M4P file type is primarily associated with 'Protected AAC File' by Apple Inc. AAC is the audio layer from the follow-on format to MP3. The .M4P extension is AAC purchased from Apple's Music Store (iTune) and is protected by a Digital Rights Management scheme.
Most songs sold through the iTunes Store are encoded using FairPlay-encrypted 128 kbits/s AAC streams in an MP4 wrapper, using M4P extension. Apple has maintained tight control of its FairPlay encryption. Other online music stores cannot sell music files encoded with FairPlay. This means that consumers who want to listen to songs downloaded from the iTunes Store must either have an iPod or convert the files to an open format. There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:\Documents and Settings\Administrator\My Documents\My Music\iTunes\iTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Sep 19, 2010 | Computers & Internet
I got a GoGear RaGa 4GB MP3 player recently and have just purchased a song from itunes. How do I get it from my computer to the MP3 player
Apple (and thus iTunes) uses a proprietary format (AAC format, not MP3) and iTunes is designed specifically to work with iPods and other Apple products.
This being said, my guess is that either your GoGear is not compatible with AAC format that you downloaded from iTunes, OR if it IS compatible with the format, it could be that iTunes does not recognize it as a device.
Either way, I would use another music library application (Windows Media Player, MediaMonkey, WinAmp, Amarok, or Songbird, to name a few) One of these may be better at recognizing your GoGear player than iTunes.
Then, if your GoGear does not support the AAC format from the iTunes store, you will want to use a converter to create an MP3 file (you can do this from inside the iTunes application, or get some thing like a media converter found here: http://sourceforge.net/projects/bonkenc/)
You could use these to convert the files to MP3 and then you should be able to transfer them to your player.
Because of the incompatibility and proprietary nature of Apple, you may want to avoid iTunes unless you have an iPod
Mar 08, 2011 | Philips Audio Players & Recorders
After Copying 100 Mp3 files my Ipode 4GB tell no music file.
What did you use to copy the files? If you just copy-pasted it using the explorer then it wont recognize the songs. Ipods need iTunes to sync music. Another excellent music manager that you can use (that can also convert files to something that the ipod understands) is MediaMonkey.
Mar 03, 2011 | Apple iPod nano
My device doesn't recognize media files on it but when connected to PC I can access files from ''My Computer'' and play them on the PC.How can this be rectified?
maybe you need to try converting the files. Its similar with my Ipod, i have to convert all files to get them to work. The easiest way it to 1) go into Itunes
2) Go file, import folder
3) Choose the music or general media
4) Convert when it asks you whether or not to convert form either WMA or MP3
Jan 22, 2011 | Apple iPod nano
How to load audio cd that's mp3 readt to a ipod
you can use Itunes to convert all Mp3's to an Ipod Format that's the only best and sfest way to prevent any corruption to the files and to the Ipod itself.
Once you installed Itunes on your PC, search all the Mp3's to have it sync to the Itune program conenct your Ipod Itunes will detect the Ipod and ask if you would like to sync your device "ipod" with Itunes I suggest you select no do not sync the ipod to youe Itunes any changes on the Itunes when you sync your Ipod will also change the way you have your Ipod setting. once the Audi Files are detected by Itunes you can drag all the music you like to your Ipod's Name on the Left side it should show once you connect your Ipod this is the only way you can upload Mp3 files to your Ipod if you don't use Itunes the Audio File may be installed in your Ipod but may not run, Apple has a different Format this is the reason why you need Itunes.
Jun 27, 2010 | Audio Players & Recorders
How to put a video on my 80 Gb ipod using mp3 rocket
You need a third party software to convert the video to the format which support by iPod.
Here I find a Video Conversion Software which could convert between all popular Video formats ( AVI, MKV, MP4, WMV, FLV, MPEG etc.) that support all popular portable media players (such as Zune/Zune HD, iPod/iPhone and PSP) and the latest iPod Nano 5G, iPod Touch 3, iPhone 3GS/OS 3.1.
Dec 21, 2009 | Apple iPod MA446LL/A MP3 Player
I have an apple Nano(2G). Running software 3.1.1 Itunes is 8.1. When I plug it in yy computer and device manager recognizes the device but itunes does not recognize the IPOD when i plug it in.
Here is a trick I have tried and it worked.
in My Computer Right Click your Ipod device and explore the memory.
in the device software choose a file and right click and open with iTunes.
if your itunes is running it should try and open in itunes.
If it doesn;t work,
Try another USB port preferrably a USB 2.0 port.
Good Luck
May 06, 2009 | Apple iPod MA446LL/A MP3 Player
Blank Menu
You need to use iTune to tranfer the songs to the iPod, The iPod does not recognize mp3,s that are transfered as file through widows explorer. iTune converts the mp3's to a file that the iPod can read. Apple got in trouble in europe for doing this. They wanted to make it so you had to buy the songs solely from them and not be able to use songs transfered to the iPod. So they got sued and had to back off and make it so iTunes will convert the normal mp3's to the version of the mp3
Feb 22, 2008 | Apple iPod nano
How to convert music from itunes to your mp3 player??
Just right click the song in iTunes and select Convert to MP3. It will make a copy of the song in iTunes that you should be able to move to your MP3 player
Jul 22, 2007 | Philips GOGEAR SA6045 MP3 Player
Denon DN-HS5500 Turntable Logo
502 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
