The fan is a function of how hot the cpu and gpu units are getting on the motherboard. If the fan is running fast it means the heat from the motherboard components is not getting passed out of the enclosure. Get some canned air and blow out the dust from all the vents around the computer edge. You could also get a laptop cooler to put under your laptop.
Zork Nemesis was written in 1996, so if you are playing with it on a modern computer it's likely that is simply too fast.
Believe it or not the only solution is slow down your wickedly fast computer to play that old game.
Take a look at this utility which is designed just for that purpose.
Try to blow out the computer dust from the case. You MUST dis-connect all power from computer and devices. Take it out on your patio and blow the dust out with the vacuum cleaner, but DO-NOT actually touch the vacumm brush oh the motherboard.
Windows XP includes a new Microsoft Natural Keyboard shortcut to lock your computer. Any other compatible keyboard that includes the Windows logo key and the Application key can also perform this task.To use this shortcut, press the Windows logo key+L. The following list has different computer lock-up scenarios that are available to you, as well as other ways to lock the computer:
Fast User Switching Enabled
loadTOCNode(2, 'moreinformation');
If the Fast User Switching feature is enabled and you lock the computer, you can observe the same behavior as if you switched users: The computer returns to the Welcome screen and other users can log on to the computer.
Fast User Switching Disabled
If the Fast User Switching feature is disabled and you lock the computer, the Unlock Computer dialog box is displayed that requires the current logged-on user to enter a password to unlock the computer.
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers. Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors. If you had trace to that problem, then replace the whole unit of hub connectors.
