Question about Audio Technica AT-LP2D Turntable
Turntable spins too fast at both speeds
  • Anonymous May 06, 2009
    Turntable spins too fast. All mechanisms (gears, belt, etc.) appear in good working order but the platten rotates too quickly producing an "Alvin and the Chipmunks" effect.
    New Friend:
PITCH CORRECTION HAS VERY LITTLE EFFECT. THE BELT SHOULD BE FINE , IT'S A BRAND NEW MACHINE
Posted on Jan 03, 2015
    President:
  • 1,285 Answers
This is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Posted on Jul 06, 2009
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Technics Sl-1210 MkII spins backwards
As the turntable was hit hard then an internal inspection should be done to look for signs of phyical damage. It could be anything from broken parts to bad soldering or a crack on the PC board. I rather suspect it should be obvious what got damaged when you look inside.
Feb 28, 2013 | Technics SL-1210 Turntable
Turntable spins to fast
The motors are a common problem with this
model! Replace it to correct but I suspect the
motor regulator ic which is not avalible is the
real problem!
Apr 02, 2010 | Sony PS-LX250H Turntable
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
Turntable Spinning too fast
ya buy new belt loose or is this direct drive
Oct 09, 2008 | Teac GF-350 CD Shelf System
My tunrtable spins backwards :S
these motors are quite cheap. You can open it up yourself and see if any resistors are burned up. If not, contact numark parts dept and order new motor. quite easy to install.
Dec 06, 2007 | Numark BATTLE PAK v.4 Turntable
Audio Technica AT-LP2D Turntable Logo
1,607 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
