Question about Black & Decker BL5000 ProBlend Work Top Blender
5 speed ...steel
My belndor stopped working after 3 to 5 use. i when i push it to work i hear it clicks... plzzz help. thnkx for your attention to this matter
  • 3 Answers
I had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, [email protected]
Posted on Jul 22, 2008
SOURCE:
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
Vitamix troubleshooting
Track continuity inside with a multi meter. Pay attention to continuity of switches, they are a bit unreliable design.
Sep 03, 2014 | Vitamix Blenders
Speed not increasing on Kitchenaid ultra 5 speed blender
The speed selection buttons for speeds 1 through 3 may have failed.
Jan 10, 2014 | KitchenAid Ultra Power 4KSB5 5Speed...
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
Blender now only has one speed and it's overspeed. Is there an overspeed govenor that causes the blender to automatically shut off? It will overspeed about 3 seconds before it stops working and all the...
there is a voltage regulator inside the circuit board , this might have got wet some how . this circuit controls 1-10 speed from a touch of a button . will have to disassemble unit , Auth personal should check this , unless you know electronics
Mar 19, 2010 | KitchenAid KSB3 Classic Work Top Blender
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Black & Decker BL5000 ProBlend Work Top Blender Logo
469 people viewed this question
Top Black & Decker Blenders Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
