Question about LG LMVM1945 Microwave Oven
Microwave Does Not Heat. Timer Works.......No Heat Display shows F-9 LG Microwave Oven/ Household Model LMVM 19455 SB Mfg. 2003
  • LG Master
  • 19,396 Answers
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Sanyo Microwave/Combi/Grill 900W em-g 47535 on front. Timer works but does not heat up code 1S on display. Any ideas
It hardly matters what code is showing because clearly the appliance is receiving power (timer works) and the internal workings of a microwave oven are potentially very dangerous and only competent people should open them up and fiddle around inside.
Sorry but the fact you need to ask shows you aren't a person competent enough to risk your neck inside a microwave. If it is a basic oven out of warranty it would be cheaper to replace it, if it is under warranty send it back and if it is a premium model it could be worth taking to the repair shop for a repair estimate.
Sep 23, 2016 | Sanyo Microwave Ovens
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
HI I HAVE A LG MICROWAVE OVEN MODEL# LMVM 2277ST ;1100W IT WORK BUT SLOW IT TAKES TIME TO WARM THE FOOD
I see by looking at the owner's manual there is an option to set power level from 0% to 100%, maybe that is set too low (see page 14 of manual). If don't have manual for that model (LMVM2277ST), can get from this web page (look near bottom of page and click words "owner's manual" that are underlined) :
http://www.ajmadison.com/cgi-bin/ajmadison/LMVM2277ST.html
Jan 15, 2011 | LG LMV1625 1000 Watts Convection /...
Turns on but doesn't heat only a year old LG LRM1260SW 1200 Watts Microwave Oven
I have had the LG model lrm1260sw microwave for 3 years. Recently it quit heating. I found the problem was the soldered grounding lug connection on the power transformer had lost circuit continuity and failed. One of the secondary coils on the power transformer, red wire / bare copper wire, is connected to ground / chassis. I cleaned the lug connection and added a length of wire twisted together with the bare copper coil wire and soldered to the grounding lug. I then grounded the extra added length of wire to another chassis ground point. Make sure the transformer to chassis mounting screws are tight also. Now the microwave oven works like new again.
Feb 27, 2010 | LG LRM1260SW Microwave Oven
Hums, does not heat when started. Display, timer,
The problem could be the high voltage fuse or the magnatron assembly. replace both to be safe. good luck.
Nov 12, 2009 | Sharp R-1610 Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace oven ligh on LG microwave
Hello Bob,
Here is a link to the service manual for your micro.. you should find everything you need to know about testing it and disassembling it as well.. Hope this helps you..
http://136.166.4.200/contents/Microwave/LMVM1945xx/LMVM1945_Service_Manual.pdf
Hope this helps you.. if it does, please rank this response accordingly..
Good Luck
Sep 30, 2008 | LG LMVM1945 Microwave Oven
LG LMVM1945 Microwave Oven Logo
244 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Will Halftowaite
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
